05-19-2020 01:09 PM - edited 05-19-2020 01:10 PM
I have a Cisco phone 8832 CUCM version 11.5.1.11900-26 the load file is sip8832.12-5-1-16.loads and the phone is not registering with Call Manager. It gets an IP address 10.X.X.X.
There is also very weird ping behavior, When I ping the ip, I get dropped packet, possibly bad cable, I will have to check, all other none 8832 Ip-phones are fine.
SW1#ping 10.X.X.X
Sending 5, 100-byte ICMP Echos to 10.X.X.X, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 1/1/1 ms
SW1#ping 10.X.X.X
Success rate is 60 percent (3/5), round-trip min/avg/max = 1/1/1 ms
SW1#ping 10.X.X.X
Device ID: SEP5CE1XYXYXY
Entry address(es):
IP address: 10.X.X.X
Platform: Cisco IP Phone 8832, Capabilities: Host Phone Two-port Mac Relay
Interface: TwoGigabitEthernet1/0/26, Port ID (outgoing port): Port 1
Holdtime : 177 sec
Version :
05-19-2020 01:41 PM
Did you install the DevPack required for it?
05-19-2020 02:07 PM - edited 05-19-2020 02:13 PM
Thanks! No I did not. where that will be? how would I check if it is installed?
I checked the device default config on call manager, I can see a load info under Dual bank info but not under Device Defaults Information
05-19-2020 10:26 PM
