02-16-2021 06:05 AM
Hello Team,
I have a problem with the phone model Cisco 8865 and here is the data:
- Phones can only call internally.
- when trying to call externally [ Mobile number, International, etc... ] call drops with an error code:
" Cause 38 Network Out of order "
- We have another phone model in the company Cisco 7821 which has same everything [ configuration, gateway, etc...] and It's working perfectly.
- ISP confirmed that there is not issue from their side.
Thank you in advance.
Solved! Go to Solution.
02-16-2021 06:38 AM
Since it happens only with video end point, and working on normal phone
Try this command under voice port "bearer-cap speech"
02-16-2021 06:38 AM
02-16-2021 07:22 AM
Disable video from the phone page , try again - if it worked fine, you will need to add a new device pool for the sip/h323 trunk then create a new region for the new device pool and disable the video between the site region and trunk region
Site-region—> site device pool, siptrk-region—> sip trunk device pool then disable video between the regions
