cisco phone announcing everything it is doing
Yenosh
Adam Pawlowski
Press select 3 times or go into applications and accessibility and disable the screen reader. In the menu press off twice like a double click or it will just say “off” and not turn off.
There was a bug if you held select it would turn this on.
Adam Pawlowski
