11-29-2015 09:55 AM - edited 03-17-2019 05:02 AM
I am trying to debug self provisioning, so I am using the same phone to auto register multiple times. I have two phone setup. They auto register, then I run self provisioining and then I need to start over. So I go into devices and delete the device so that it can auto register again. This one phone, gets the "Phone Registration Rejected error" and it has re-registered several times before, but is now stuck in this condition. This is on a BE6KS a self contained CUCM cluster on a 2921 router.
11-29-2015 12:25 PM
If you're using the same user/DN, how many devices did you configure to allow self-registration before preventing the user from registering another device.??
11-29-2015 12:49 PM
The same user DN to auto register? So there are two steps; first the phone uses the auto registration function (which is configured and working with a 100+ range of numbers) to obtain a device registration. Then the user presses the self provisioning button on the phone to talk to that IVR application. I have no trouble deleting the device and starting over with several other phones 7941 but this one 7970 phone will not re-register. The SEPMAC has been deleted from the registered devices like all the others. I even factory reset the phone. No Joy.
All this to trouble shoot a self-provisioning problem in which the fields defined in the device line template do not show up after the phone is provioned. The phone gets the new user ID and Extension number, but the User Name as defined in the template do not show up. Thus why I keep deleting the phone and tying again after making template changes.
11-30-2015 10:41 AM
5 - but the phone would have to register first, before you can auto provision triggering this parameter. If you delete the device the phone should reregister.
