05-06-2011 11:45 AM - edited 03-16-2019 04:51 AM
This is my first time posting to the Cisco Support Communities. I have been researching how to implement call accounting for a client with a Cisco 3825 router with IOS version 12.4(20)T6 (SPSERVICESK9-M). I enabled File Type Accounting on the router and have it sending detailed CDR records daily to an FTP server as CSV. I sent the resulting file to a few call accounting software companies to integrate with their systems, and they have all told me that the CDR files are incomplete, missing such important information as CLID & DNIS. I did not originally program this phone router for the client, and have no experience configuring Cisco routers for voice communication. I need to know how to configure the router to include this needed information in the CDR files generated by the router. Attached is a CDR file from their router.
I am not looking for a definitive answer, just someone to point me in the right direction for me to continue my research/troubleshooting as I am not finding any similar posts in the Cisco support communities or online in general. Please let me know if you have any questions, or if this thread should be posted to a different support community. Thank you in advance for your help. I appreciate it.
-Tim
05-08-2011 04:52 AM
There is no need to use large attachment.
Just post few lines of the mentioned CDR logs and mentioned what exact type of connection to telco you have.
05-09-2011 11:57 AM
I am not sure what connection they have with the Telco, but I will provide that info once I find out. Below are a few lines from the CDR file output:
1303670526,8906,0,2,"67B20A73 6DD711E0 91660016 47BAC0F0","","","14:27:54.599 EST Sun Apr 24 2011","","14:27:54.599 EST Sun Apr 24 2011","14:42:06.499 EST Sun Apr 24 2011","","","",0,"",42569,6811040,42571,6811360,"","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",852,"","","0","10.250.2.146","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","other","","","TWC","04/24/2011 14:27:54.623","","",0,8906,67B20A73 6DD711E0 91660016 47BAC0F0,22CA,"","","",""
1303670526,8905,0,1,"67B20A73 6DD711E0 91660016 47BAC0F0","","","14:27:54.597 EST Sun Apr 24 2011","","14:27:54.597 EST Sun Apr 24 2011","14:42:06.507 EST Sun Apr 24 2011","","","",0,"",42571,7151928,42591,6814560,"","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",852,"Tariff:Unknown","","0","","","","","","","","","","","","","0/3:1","","","","","","","","","","","","","","","","","","","","","","","","","","","","","TWC","04/24/2011 14:27:54.623","","",0,8905,67B20A73 6DD711E0 91660016 47BAC0F0,22C9,"","","",""
1303670526,8908,0,2,"67FB49EE 6DD711E0 91670016 47BAC0F0","","","14:27:55.087 EST Sun Apr 24 2011","","14:27:55.087 EST Sun Apr 24 2011","14:42:06.551 EST Sun Apr 24 2011","","","",0,"",42063,6730080,42061,6729760,"","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",851,"","","0","192.168.19.52","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","other","","","TWC","04/24/2011 14:27:55.103","","",0,8908,67FB49EE 6DD711E0 91670016 47BAC0F0,22CC,"","","",""
1303670526,8907,0,1,"67FB49EE 6DD711E0 91670016 47BAC0F0","","","14:27:55.089 EST Sun Apr 24 2011","","14:27:55.089 EST Sun Apr 24 2011","14:42:06.559 EST Sun Apr 24 2011","","","",0,"",42061,7066248,42570,6811200,"","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",851,"Tariff:Unknown","","0","","","","","","","","","","","","","0/3:2","","","","","","","","","","","","","","","","","","","","","","","","","","","","","TWC","04/24/2011 14:27:55.103","","",0,8907,67FB49EE 6DD711E0 91670016 47BAC0F0,22CB,"","","",""
1303670626,8910,0,2,"875E20F0 6DD911E0 91680016 47BAC0F0","","","14:43:06.758 EST Sun Apr 24 2011","","14:43:06.758 EST Sun Apr 24 2011","14:43:46.948 EST Sun Apr 24 2011","","","",0,"",1996,319360,1998,319680,"","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",40,"","","0","10.250.2.144","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","other","","","TWC","04/24/2011 14:43:06.753","","",0,8910,875E20F0 6DD911E0 91680016 47BAC0F0,22CE,"","","",""
05-10-2011 04:11 AM
Never seen cisco CDRs having the format above. Please refer to the following uide for configuration:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094e72.shtml
05-11-2011 09:53 AM
The link you sent me looks good, except that we are using file type accounting, sending the file to a computer via FTP. If I ignore the gw-accounting steps in the guide you referenced, should I make sure everything else is setup correctly in router config, or are all the other settings dependent upon the accounting type?
05-09-2011 01:26 PM
This client has 3 PRI connections with the Telco. Is that what you were referring to?
