Cisco Phone VPN-trust certificate
S Sadiq
How to upload the Cisco Phone VPN-trust certificate in cucm and what are pre check and post verification I have to follow.
6 Replies 6
Jonathan Schulenberg
Here are the relevant documents. Let us know if you have a more specific question after reading them.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cucos/10_0_1/CUCM_BK_C2F2626C_00_cucm-os-admin-guide-100/CUCM_BK_C2F2626C_00_cucm-os-admin-guide-100_chapter_0110.html#CUCM_TP_M7B4E6D3_00
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/115785-anyconnect-vpn-00.html
Thanks Jonathan.
I don't understand your question.
He already posted this on another thread
https://supportforums.cisco.com/discussion/13191951/data-migration-one-site-another
java
if this helps, please rate
I thought I'd reach out to the Cisco Community experts, since I haven't been able to find confirmation on this one.
Our phone-vpn certificate recently expired and we are in the process of uploading a new one.  I've read through the posted link below, however my question is, instead of creating a new VPN Gateway configuration, can't I just switch out the vpn certificates from the Truststore?
Instead, of creating a completely new VPN Gateway, Profile, group, etc...
Or is it best practice to just create a new one from scratch once the new phone-vpn trust certificate is uploaded?
Any feedback or suggestions will be greatly appreciated!
Thank you,
Diana
Hi All,
In case this helps anyone or for those who may have the same question.  I ended up uploaded the new phone-vpn trust certificate and just switched it out from the CUCM > Advanced Features > VPN Gateway - Truststore - Saved.  I then deleted the expired phone-vpn trust certificate.
For testing, I simply used one of the vpn phones, confirmed Common Phone profile was set correctly and tested login.  All was successful.
Thanks!
-Diana
