187
Highlighted
Beginner
Cisco phones calling without control
Greetings
I have my cisco phones on a 2811 calling same number simultaneously
Thats 251 calling 251 and 201 calling 201
How can i solve this problem
3 REPLIES 3
Highlighted
Hall of Fame Cisco Employee
Is this the same phone model?
Is this the same phone model??
Have you tried upgrading the FW or swapping the IP Phone for other one?
Do you have anything special in the config for those 2 DNs??
java
if this helps, please rate
Highlighted
Beginner
The 2 phones is just an
The 2 phones is just an example
i have more than 20 phones ranging from 7911 to 7975
There is o special config
Highlighted
Could you please delete and re-add the phones. Do "no create cnf" and then "create cnf" and reset the phone to register them again.If the issue still persists, please upgrade the firmware of the phones and check if that resolves the issue.
If the issue still persists, please collect the following logs for a test sample:
debug ephone detail mac-address <mac address>
~Amit
Content for Community-Ad
Cisco COVID-19 Survey
