03-13-2012 08:04 AM - edited 03-16-2019 10:05 AM
Would someone be kind enough to tell me how many PLAR's are support on CUCM 8.
I am currently running CUCM 8.0.3 and a C2851 ISR as my gateway.
Many thanks
03-13-2012 08:10 AM
There's no hard limit, the only limit is HDD space since all that creates entries in the DB
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-13-2012 08:21 AM
Thank you for that info Java,
Is there a limit on the amout of dial-peers you can have on the gateway? obviously there will be some limit for pots as it will require timeslots on E1 and T1 cards or FXO/FXS cards.
Joe
03-13-2012 08:41 AM
Solution # | K34857008 |
Title | How to determine the maximum number of dial-peers that can be configured on a router |
Resolution | The dial-peer options are available based on how much memory is available. As an example, assume each dial-peer consumes 6k of memory, and that the router does not accept new dial-peers at the 80 percent threshold of memory allocation. This formula calculates the available dial-peer options: (Free Memory * 0.8)/6k = maximum theoretical number of configurable dial-peers This number represents the upper limit. These points must also be considered:
Caution: More dial-peers can adversely affect the performance of the router. Issue the show memory command in order to determine the amount of memory that is used. |
http://topic.cisco.com/taccc/voice_K34857008.html
java
