Cisco Prime Provisioning
ravi ahuja
Any help for POC of Cisco prime Provisioning will be appreciated.
 As per the CISCO PDI they don't support this and I am unable to find much information on Cisco.com. I need help for setting up this product and integrating with CUCM for real life use.
Manish Gogna
Hi Ravi,
If you are looking at information on what PCP does, how to install, how to configure its various features etc then you will find all this documentation in the following couple of links
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/11-5/provisioning/guide/Cisco_Prime_Collaboration_Provisioning_Guide_11_5.html
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/11-5/documentation/overview/Cisco_Prime_Collaboration_Provisioning_Documentation_Overview_11_5.html
If you have any other specific queries you can get back to the forum with the same.
Manish
- Do rate helpful posts -
Dear Manish
I have installed Provisioning 12.1 but can only user GUI and have issue accessing the CLI.
Auto created user id - globaladmin works for GUI but I am not getting any clue as how to access CLI.
Th eonly way I could figure out from Cisco documentation is with troubleshooting user that can be created by TAC only.
Any info on this will be highly appreciated.
