04-03-2013 03:46 PM - edited 03-16-2019 04:35 PM
I have a customer that has expired ESW but still has UCSS. I got word that there is a reinstatement sku (L-REINST-UWL-STD) but this isn't in CCW. Can anyone shed any light on this?
Solved! Go to Solution.
04-04-2013 11:28 PM
I suggest you take a look at the CUWL v9 OG , you need to use the top level SKU:
I just tested it and it works
Reference:
Best Regards
Jaime
04-03-2013 10:17 PM
I also checked on CCW site but meesage comes not available .
Also, checked on Ordering Tool , also not available there. Is this the correct PART CODE?
regds,
aman
04-04-2013 11:28 PM
Reference:
Best Regards
Jaime
04-04-2013 11:36 PM
Hi Jaime,
Thanks for info.
I was just referring the same CUWL Ordering guide when your post came.
Can u share the exact URL in CCW ?
regds,
aman
