Cisco RIS70 Status Code 6 and 32
eksantrik
Hello folks:
I keep seeing these two reason codes for status in RIS return. I checked the following but couldn't find them:
https://developer.cisco.com/docs/sxml/#!risport70-api-reference/selectcmdeviceext
Where can I find the full list of status codes?
Chris Deren
Not sure why the documentation is incomplete, from he following doc I believe this is the correct reason for 6, but I don't see 32:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/err_msgs/8_x/ccmalarms861.html
6 - ConnectivityError - Network communication between the device and Unified CM has been interrupted. Possible causes include device power outage, network power outage, network configuration error, network delay, packet drops, and packet corruption. It is also possible to get this error if the Unified CM node is experiencing high CPU usage. Verify that the device is powered up and operating, verify that network connectivity exists between the device and Unified CM, and verify that the CPU utilization is in the safe range (you can monitor this via the CPU Pegging Alert in RTMT).
