Cisco Router Config for Meeting Place
jason2g6114
Good evening,
I started at a place that installed Cisco Meeting Place many years ago. Yesterday the Cisco 2821 that was terminating the T1's had a hardware failure. We have received a replacement but they never saved the configuration to memory so there is no configuration on it at all. I did find some documentation and was able to get the internal conferencing working but the outbound calling is not working. We verified that the trunks were never even trying to call out. There is one command on each controller that I am not able to issue on this router. The command is below. Can anyone please look at the configuration and please assist in any way. Thanks for your time in advance. The router is running c2800-advipservices-15.0.
controller T1 0/0/0
 desc From PBX 02B04
 framing esf
 linecode b8zs
 cablelength long 0db
 ds0-group 0 timeslots 1-24 type e&m-wink-start
 trunk-group OutboundTG timeslots 1-24 preference 1
Configuration Currently
card type t1 0 0
card type t1 0 1
logging buffered 51200 informational
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
trunk group OutboundTG
trunk group dspfarm
 hunt-scheme sequential both
voice-card 0
 dspfarm
 dsp services dspfarm
controller T1 0/0/0
 description From PBX 02B04
controller T1 0/0/1
 description From PBX 02C05
controller T1 0/1/0
 description From PBX 02C06
voice-port 0/0/0:0
voice-port 0/1/0:0
voice-port 0/0/1:0
dial-peer voice 1 pots
 direct-inward-dial
dial-peer voice 2 pots
 trunkgroup OutboundTG
 description LD/Toll Free Calling
 prefix 91
dial-peer voice 3 pots
 description Local Calling
 prefix 9
dial-peer voice 4 pots
 description 4-Digit
dial-peer voice 11 voip
 description To Meetingplace Application Server
 preference 1
 destination-pattern 3145
 session protocol sipv2
 session target ipv4:151.126.194.160
 session transport tcp
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711ulaw
 fax-relay ecm disable
 fax rate 14400
 ip qos dscp cs3 signaling
 no vad
David Lee
I'm fairly certain that you can not assign a trunk group to the controller itself and that you have to assign them to the  voice ports
voice-port 0/0/0:0
voice-port 0/1/0:0
voice-port 0/0/1:0
Try assigning the trunk group to the correct voice-port in your setup and see if that works.   Its the same with FXO Ports.   Snippet from a 2901 with a 4-port FXO card.
voice-port 0/1/0
 trunk-group SRST-OUT
 timing hookflash-out 50
 connection plar opx 4093
 caller-id enable
voice-port 0/1/1
 caller-id enable
voice-port 0/1/2
 caller-id enable
voice-port 0/1/3
 caller-id enable
David Lee
voice-port 0/0/0:0
voice-port 0/1/0:0
voice-port 0/0/1:0
voice-port 0/1/0
 caller-id enable
voice-port 0/1/1
 caller-id enable
voice-port 0/1/2
 caller-id enable
voice-port 0/1/3
 caller-id enable
Suresh Hudda
Hi Jason,
Outgoing call won't work here because you have not mentioned destination-pattern under pots dial peers :-) 1st mention it and then test, if still there is a issue then pls attach "debug voip ccapi input" and "debug isdn q931" for a failed call.
Suresh
