09-20-2016 05:15 AM - edited 03-17-2019 08:08 AM
Dears All
we have AVAYA IP Phone (1011) registered witch cucm 11 ,when we calling sccp cisco ip phone (1005 ) the call success , but when we try to call avaya phone 1011 from cisco phone 1005 the avaya phone not ringing and no dialtone on cisco phone
kindly find traces files
Solved! Go to Solution.
09-20-2016 05:26 AM
09-20-2016 05:26 AM
09-20-2016 05:31 AM
\\ After few sec SCCP phone goes OnHook\\
00030318.001 |15:07:13.343 |AppInfo |StationInit: (0000011) OnHook.
\\ Call Released with cause value 16\\
00030332.000 |15:07:13.343 |SdlSig |CcRelInd |call_initiated1 |LineCdpc(1,100,177,44) |LineControl(1,100,176,13) |1,100,14,961.35^10.10.200.21^SEP189C5DB6274C |[R:N-H:0,N:4,L:0,V:0,Z:0,D:0] CI=25429485 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 CV=16 isDeskPickup=F dtmDisconn=F FDataType=0 opId=0 ssType=0 SsKey=0 invokeId=0 resultExp=F bpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
09-20-2016 05:54 AM
But could you explain the reason of that and how can i solve it ?
09-20-2016 09:08 AM
Problem on Avaya side. You have to engage Avaya Experts
10-07-2020 03:05 AM
I have the same issue, I registered Avaya SIP phone to Cisco CUCM, and Avaya phone can make calls, but can't receive any calls.
I've tested the same SIP extension on another soft SIP phone and it worked well.
RTMT shows that the CUCM send the invite message to the Avaya phone but no response. the call hang after a few seconds.
I see that this topic marked as solved, but where is the solution, anyone can lep please
