Cisco SCCP "Can't" Message
Ccoria1989
Beginner
Beginner
I am having troubles with a Cisco IP phone but in traces I see this message:
Outbound SCCP message to 150.211.102.45 at 08/18/2015 09:56:27.242
StationD:    (0051062) Can't forward DeviceMediaPortCloseMsg to cdpc for CI 49018231; can't find it.
Source Filename: SDL002_100_001192.txt.gz
I tried to find what's the meaning of that message but I can't find anything.
This is a fragment of my call flow.
150.211.102.45 IP Phone
150.211.101.253 CUCM
150.211.101.251 Voice GW
I hope you can help me.
5 Replies 5
Manish Gogna
Can you please tell what the exact issue is? What is the cucm version, phone model and firmware?
Manish
Hi Manish
The exact issue is that we see in CUCM traces a "500 internal Server Error" when some calls are assigned to that phone.
And in Gateway debugs we see the same error.
 This is a Contact Center Enterprise we have all the SIP trunks between CUCM and CVPs and Gateways.
And not all the calls fail.
CUCM version is 9.1(2)
The extension is an extension mobility profile for 7942 SCCP.
Regards.
j.huizinga
Frequent Contributor
PortRes has to do with SCCP "Early Offer"
Can you check if the INVITE has early offer?
Or check if MTP is enabled on the SIP trunk
Ths is the INVITE:
32342449.002 |09:56:30.154 |AppInfo  |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 887 from 150.211.101.251:[59242]:
[34882935,NET]
INVITE sip:4120@150.211.101.253:5060 SIP/2.0
Via: SIP/2.0/UDP 150.211.101.251:5060;branch=z9hG4bK4AD0522A
Remote-Party-ID: "FERRER,MORALES --CVP_9_0_1_0_0_0_670" <sip:10976@150.211.101.251>;party=calling;screen=no;privacy=off
From: "FERRER,MORALES --CVP_9_0_1_0_0_0_670" <sip:10976@150.211.101.251>;tag=5A12F990-11EC
To: <sip:4120@150.211.101.253>
Date: Tue, 18 Aug 2015 14:56:30 GMT
Call-ID: 249A8609-44F011E5-A22BFBAC-D323C2B@150.211.101.251
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0131335732-1153765861-3031141964-2852120472
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1439909790
Contact: <sip:10976@150.211.101.251:5060>
Expires: 60
Allow-Events: telephone-event
Max-Forwards: 68
Content-Length: 0
 And no, the MTP is not enabled on the SIP Trunk.
Regards.
j.huizinga
No early offer in the INVITE
Try to enable MTP on the SIP trunk, by default I always enable this, because it solves a lot of issues. Try to use IOS MTP resources, CUCM has some limited MTP resources
