Cisco SIP IP Phone 8851/8841: delay in dialing
ysanadiga01
Hi there,
I've a Cisco CUCM version 11.x with Cisco SIP IP Phone devices 8851 and 8841. When I call internally (4 digits) from one SIP phone to another phone, there's always a delay of 4 or 5 seconds exactly. There's no overlapping numberplan (checked via DNA).
Anybody know why this is happening and how to solve it.
Thanks.
You can enable urgent priority under your DNs using bulk administration. this will resolve your problem.
10 Replies 10
Are the phones and CUCM in the same LAN?
Also, under DN config check the option 'urgent priority' and see if it fixes the problem. If so, then you are indeed having overlapping patterns
Jaime Valencia
What's the T302 timer set to in your environment??
If it matches the same delay you're seeing, most likely you do have some overlapping going on.
java
if this helps, please rate
Hi Jaime,
The timer is set to 4 seconds which is equal to delay.
How I can check for overlapping? I have checked the route patterns and I have created route patterns for various kinds of calls like international, national, mobile and so on.
Thanks.
Look at your route plan report, and since you mentioned that you checked route patterns (and don't mention anything else), I need to clarify that your dial plan is comprised of EVERYTHING you have configured in CUCM, ANY DN or pattern.
java
Hi Jaime,
Thanks for your reply.
I'm attaching the Route Plan Report. I hope you can find something from it. (I've omitted the Description field from it).
Regards.
Your DNs are overlapping with a route pattern XXXX#. If you don't need it then you can remove this pattern
Hi Mohammed,
Thanks for your reply. Actually I do need that Pattern. I will try to think how I can solve this issue.
Regards.
Hi Mohammed,
I have already done that as a workaround. I was thinking if I can solve without enabling Urgent Priority of deleting the Pattern.
Thanks.
cbg_inst1
what ws the solution?
Catumbila Gonçalves
