Cisco SIP IP Phone are unable to load Config from TFTP (unprovisioned)
Vikrant Ambhore
Hi All Friends,
We have CISCO IP phone 7941 for using VOIP from SIP provider, IINET is providing to us,  It has default SIP Image, it is New SIP phone, I configured below attached code in Xml file(SEP001B2AC76B9A.cnf.xml) & keep on TFTP Server but I saw on TFTP Server phone got config from TFTP, but phone saying error unprovisioned,
I think my config is correct, but please anyone help me
Kindly Help me
Vikrant
20 Replies 20
Dear Rermanh,
As per your Suggestion I Installed X-lite 4.0, Everything is fine on that, I can Make Call from Softphone also can receive call,
Bro I am very tired from 7941G, Not sure why it's not working, pls help me, can u give me ur Skype or Gtlak ID if Possible
Don't use skype or other.
post your latest config.
Ok Dear,
No prob, Thanks for your Intrest to help me, Please look on my attached config
Vikrant
In another thread, you had been warned that using 79xx for ITSP is NOT recommended.
But you tough you know better.
Ok,
I've edited as I think it should be. Add your settings as appropiate on these lines:
XXXX
   XXXX
   XXXX
  XXXX
Also note that you had the worng proxy set under
You had this 203.2.134.1 and I've set to this 203.55.229.194 (assuming it's your provider sip.vic.iinet.net.au)
Also ensure your provider allows G729a codec as this is what is specified in the file.
You also had this ip 203.0.178.91 specified as your 203.0.178.91 in the xmldefault.cnf.xml which should be 203.55.229.194 (assuming once again that your provider is sip.vic.iinet.net.au)
I also changed the load information to this SIP41.8-3-1S
Your ntp server is pointing to this and I'm not sure if that was intended and whether they offer ntp services which I havent checked. Although this shouldn't affect registration:
vhosts.iinet.net.au
203.0.178.91
Apart from this I'm afraid I cannot offer any more help.
Read the link I sent which is pretty informative
http://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79x1+xml+configuration+files+for+SIP
Both files attached
joro
I've seen the unprovisioned message with SIP phones that were in Call
Manager but had no DN configured on the phone.
