Cisco SIP phones 3905 don't get registered in SRST
omni.moreno
SRST 9.1
CUCM 8.6
We have set 74 phones enable in CUCM to register in SRST, however only 7 phones got registered while in SRST.
Any ideas from where to start checking?
Thx,
dsobrinho
Level 9
Level 9
Hi Omni,
Easy to answer my friend. This phones are SIP you will need configure the (voice register global) and (voice register pool  1) to register them. Note that in voice register pool in the first line ( id network) is your local voice network. The secound line will be  CUCM address . when this address is reachable again, the phones back to register on CUCM.
config term
timeouts interdigit 2
system message SRST-MIAMI
max-dn 4
max-pool 4
voice register dn  1
number 4310
voice register dn  2
number 4311
voice register dn  3
number 4312
voice register dn  2
number 4313
id network 10.4.10.0 mask 255.255.255.0
proxy 10.10.10.6 preference 1 monitor probe icmp-ping
dtmf-relay rtp-nte
voice-class codec 1
call-forward b2bua busy 80000
call-forward b2bua noan 80000
!The Callmanager fallback will used only for your skinny phones. So try to added  correct number of DN and PHONES !and remmember that the license of SRST will deduct the amount of phones that you declare as sip and skinny.
call-manager-fallback
video
  maximum bit-rate 2048
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
user-locale PT
timeouts interdigit 3
ip source-address 10.4.10.1 port 2000
max-ephones 236               ---------------------------> 236 skinny + 4 SIP phones = 240 phones in SRST
max-dn 236 dual-line
system message primary SRST MIAMI
system message secondary SRST
transfer-pattern ....
voicemail 80000
call-forward pattern ....
moh "flash:music-on-hold.au"
multicast moh 239.1.1.1 port 2000
time-zone 17
time-format 24
I hope help you with this information.
Tks
Daniel
Daniel Sobrinho
Hi Daniel,
Those parameters are already configured as you can see from the output attached to this thread.
Hi Omni,
Please send me the complete output you can remove login, password and the address. I need only the output of configuration, as well as the show version.
tks
Daniel
Daniel Sobrinho
