Cisco softphone
cemil.heyderov
Hi Dear Friends
i use cisco softphone. when operator answer for english press 1 for russian press 2. but i press 1 or 2 not work. how can i resolve it. sorry my english
Sadav Ansari
Are you dealing the number internally or externally?
if externally then check on voice gateway check the dtmf-relay on the voip dial peers.
You can change the below DTMF Command on your VoIP dial peers.
dtmf-relay sip-notify rtp-nte
to
dtmf-relay rtp-nte sip-kpml
Pls rate if its “Helpful”. If this answered your question pls click “Accept as Solution”.
