cisco TAPI for 64 bit systems
mesarasimth1
Beginner
Beginner
There is a plugin in Cisco Call Manager version 8.0 named "Cisco Telephony Service Provider". It can be installed in 32 bit windows clients and it is not applicable in 64 bit windows client. Is there any workaround to run Cisco TAPI with 64 bit systems?
Thank You
Manish Gogna
The native TSP 64-bit client is available in Unified CM 8.5(1) Service Update 1and higher.
Manish
Is it compatible with Unified CM 8.0? If so, how can we find it?
Thank You!
Its not compatible with cucm 8.0 , you need to upgrade to cucm 8.5.1 su1 or higher.
Manish
What about running SIPTAPI? Can we run SIPTAPI with Call Manager? If so, is it ok with all 32 and 64-bit clients and is it necessary to upload any driver in the server?
We have just tried this solution and the following error occurred while placing a call with windows dialer.exe
Recognize Your Peers
