05-23-2017 12:04 AM - last edited on 03-17-2019 10:24 AM by NikolaIvanov
We have a problem when we registering device to CUCM.
ERROR: Provisioning Status
Provisioning failed: Endpoint LSC does not match LSC on the CUCM and no upgrade CAPF operation is pending
I'm referring to this document;
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/codec-c-series/tc6/administration_guide/administering_endpoints_running_tc6_on_ucm911.pdf
Can anyone help?
Thanks.
05-23-2017 04:52 AM
You can try the following:
Go to the Web-Interface of the SX20 codec and turn off the provisioning.
Then go to CUCM>>Certification Authority Proxy Function (CAPF) Information>>Certificate OperationRequired Field:INSTALL/UPGRADE Authentication ModeRequired FielD>>By null string.
Apply config.
============== Go to the Web-Interface of the SX20 codec, turn on provisioning and Restart the codec.
You may also try changing from TLS to TCP and test the Codec.
Manish
- Do rate helpful posts -
05-23-2017 11:35 PM
