09-30-2010 12:19 PM - edited 03-16-2019 01:06 AM
Does any one have qos and switch configs related to HP Switches running Cisco UC ?
specifically models such as
a. HP Procurve 5406zl
b. HP Procurve 3500yl
Solved! Go to Solution.
09-30-2010 02:33 PM
I have not dealt with those specifially, but this is what I have done on other models:
Create VLAN for Voice
conf t
(config)# vlan 112
(vlan-112)# voice
(vlan-112)# end
Set QoS Priority on a VLAN
(config)# vlan 112 qos priority 6
vlan 112
name "VLAN112"
no ip address
qos priority 6
voice
exit
10-01-2010 09:35 AM
Apologies. I am on the road until Monday and missed that in your post. I just stopped for lunch and this is all I have onhand at the moment. I hope it helps you.
10-01-2010 09:51 AM
Hey Sankar,
Long time my friend! Hope life is treating you well
Have you looked at this doc;
Interoperability between Cisco Unified IP 7900
Series phones and ProCurve switches
Cheers!
Rob
09-30-2010 02:33 PM
conf t
(config)# vlan 112
(vlan-112)# voice
(vlan-112)# end
vlan 112
name "VLAN112"
no ip address
qos priority 6
voice
exit
09-30-2010 08:16 PM
Thank you Joel, thats a very good start. I am interested also in
a. how to configure trust boundary with ipphones and pc's
b. how to cnfigure qos like in cisco switches assuming pcs are using ip communicators
c. configuring queue depths, dscp maps..etc like in cisco switches like 3560/3750 etc..
are there good white papers out there for this ? Or do you have a sample config you can send me ?
Very much appreciated..
10-01-2010 03:15 AM
For basic IP Communicator QoS see if "auto qos voip cisco-softphone" is acceptable.
3750-X/3560-X: http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_53_se/configuration/guide/swqos.html
10-01-2010 09:06 AM
Joel,
I know Cisco qos, i wasnt looking for Cisco switching qos, i was asking if you have any white papers or sample configs on the qos configs on a HP switch..specifically with hard ip phone and Pc as well as hard ip phone, PC + soft phone etc...
10-01-2010 09:35 AM
10-01-2010 09:51 AM
Hey Sankar,
Cheers!
Rob
10-07-2010 08:51 AM
hi rob, long time..i have been so busy ...i have completely stopped responding at the forums
hope all is well
09-30-2010 02:35 PM
I would just make sure to double check the port queue and 802.1p priority values for your specific HP models.
