529
Brendan Marmont
Beginner
Cisco UC Virtualised Apps - Attendant console
Looking for a possible solution for a HCL incompatibility we have.
Our DL380pG8 have XEON E5-2680 CPUs @ 2.7GHz, the http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications specifies the CPU type is not supported for the Unified Attendant Console, yet IT IS supported for the Call Manager? Seems a bit rediculous Cisco would want us to fork out for a new server or upgrade a bunch of CPUs for the service???
Do Cisco intend to add more CPU types to it's compatibility list once tested, has anyone deployed the Attendant on a CPU type that is not supported?
Thanks for your reply,
Brendan
3 REPLIES 3
Gajanan Pande
Brendan,
It looks negative as of now but you might want to post your query on ARC Solution's forum here http://forum.arcsolutions.com/index.php
GP.
Pls rate the post if it helps !!
ARC is not accepting registrations just at the minute, but thanks for your suggestion, I will try again this afternoon
Brendan,
Those CPU's are supported with the Attendant Console, the wiki page has been updated accordingly.
Create
Recognize Your Peers
Content for Community-Ad
