03-28-2013 03:13 AM - edited 03-16-2019 04:30 PM
We are on the Cisco UCSS workspace licensing track.
My understanding is that the only licenses for users are Standard and Professional licenses.
However, I have just seen a license called the CUWL-entry.
Does anyone know anything about this type of license.
Does it include a voicemail license.
Any information gratefully received.
Dominic
Solved! Go to Solution.
03-28-2013 03:44 AM
Hi Dominic,
Please find below info and link on User Connect License/CUWL Faq which says about Call Manager 7.1.5.
Q.Will the legacy licensing model go away? What about customers on existing releases?
Ans. As of release 8.0 (and subsequently 7.1(5) for Cisco Unified Communications Manager), the licensing options are Cisco Unified Workspace Licensing (CUWL) and User Connect Licensing (UCL). Customers on previous versions of products may continue to add servers (server licenses), phones (DLU’s), mailboxes, etc per the legacy licensing model. As soon as the customer migrates to 8.0 or 7.1(5), however, they no longer may use the legacy licensing for their products.
For more, clarity u can speak to Cisco SE/AM.
regds,
aman
03-28-2013 03:28 AM
Hi Dominic,
CUWL bundles UCM, Unity, Contact Center, conferencing, and other collaboration applications in one of four different editions (Entry, Business, Standard, and Professional).
CUWL-Entry consists of functionality like SNR,CIPC ,IME and Call Control.
For messaging , u need to have Standard Edition.
regds,
aman
03-28-2013 03:33 AM
Thanks Aman for your reply,
I am wondering if these bundles can be applied to any version of CUCM as we are still
on 7.1.5
03-28-2013 03:44 AM
Hi Dominic,
regds,
aman
03-28-2013 04:47 AM
Hi Aman,
Thanks for your help with this.
03-28-2013 06:54 AM
Just to clarify since you asked about UCSS. UCSS is not a license it is software assurance support which entities you to major upgrade of the applications covered under purchased licenses. ESW smartnet is required to purchase UCSS. UCSS goes with both CUWL and UCL based licensing.
HTH,
Chris
03-28-2013 07:18 AM
Hi Chris,
Thanks for this clarification.
dominic
