Hi all,
I want to incorporate Directory Search on windows jabber without AD, I already Did it, using the UDS service on cisco, I've reading about this, It says this is only available en version 8.6.2+, I have that versión in my lab, but in production I haver the version 8.6.1.20000-1,
And on thar version (production) I haven´t installed presence yet,.
PLEASE! Tell me it works on 8.6.1.20000-1,
If it doest, could you please adviseme how to do an smooth and transparent upgrade to 8.6.2?
I hope it works please.
References:
https://wiklunds.wordpress.com/2012/04/23/setting-up-cisco-jabber-for-windows/
THANKS!
Solved! Go to Solution.
No, it doesn't
Cisco Unified Communications Manager User Data Service UDS is supported on Cisco Unified Communications Manager version 8.6.2 or later.
You can go to any 8.6(2) releases from your version, just follow regular upgrade steps.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
No, it doesn't
java
I didn't want to hear that answer, but thankyou any way.
I am going to install CUCM 8.6.1 n my lab hoping cisco is worng, I've alaready found incorrect documentation con cisco's site concerning support and capabilities features.
I'll tell you later,
Regards.
There's no error and I know for a fact it's not there, the service just doesn't exist on 8.6(1)X
System version: 8.6.1.10000-14
Cisco Trust Verification Service[STARTED]
Cisco UXL Web Service[STARTED]
Host Resources Agent[STARTED]
System version: 8.6.2.20000-2
Cisco Unified Mobile Voice Access Service[STARTED]
Cisco User Data Services[STARTED]
java
Hi javalenc, Thanks for your post, and the way to verify that.
admin:show version active
Active Master Version: 8.6.1.20000-1
Active Version Installed Software Options:
localeinstaller
admin:utils service list
Requesting service status, please wait...
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Cisco User Data Services[STARTED] <<-
MIB2 Agent[STARTED]
Platform SOAP Services[STARTED]
SNMP Master Agent[STARTED]
I think this is my lucy day! isn't it?
Reggards.
Services comparation (sorted)
Services Active Master Version: 8.6.1.20000-1 | Services Active Master Version: 8.6.2.20000-2 |
>> Return code = 0 | >> Return code = 0 |
A Cisco DB Replicator[STARTED] | A Cisco DB Replicator[STARTED] |
A Cisco DB[STARTED] | A Cisco DB[STARTED] |
Cisco AMC Service[STARTED] | Cisco AMC Service[STARTED] |
Cisco Audit Event Service[STARTED] | Cisco Audit Event Service[STARTED] |
Cisco AXL Web Service[STARTED] | Cisco AXL Web Service[STARTED] |
Cisco Bulk Provisioning Service[STARTED] | Cisco Bulk Provisioning Service[STARTED] |
Cisco CallManager Admin[STARTED] | Cisco CallManager Admin[STARTED] |
Cisco CallManager Cisco IP Phone Services[STARTED] | Cisco CallManager Cisco IP Phone Services[STARTED] |
Cisco CallManager Personal Directory[STARTED] | Cisco CallManager Personal Directory[STARTED] |
Cisco CallManager Serviceability RTMT[STARTED] | Cisco CallManager Serviceability RTMT[STARTED] |
Cisco CallManager Serviceability[STARTED] | Cisco CallManager Serviceability[STARTED] |
Cisco CallManager SNMP Service[STOPPED] Service Not Activated | Cisco CallManager SNMP Service[STARTED] |
Cisco CallManager[STARTED] | Cisco CallManager[STARTED] |
Cisco CAR DB[STARTED] | Cisco CAR DB[STARTED] |
Cisco CAR Scheduler[STARTED] | Cisco CAR Scheduler[STARTED] |
Cisco CAR Web Service[STARTED] | Cisco CAR Web Service[STARTED] |
Cisco CDP Agent[STARTED] | Cisco CDP Agent[STARTED] |
Cisco CDP[STARTED] | Cisco CDP[STARTED] |
Cisco CDR Agent[STARTED] | Cisco CDR Agent[STARTED] |
Cisco CDR Repository Manager[STARTED] | Cisco CDR Repository Manager[STARTED] |
Cisco Certificate Authority Proxy Function[STOPPED] Service Not Activated | Cisco Certificate Authority Proxy Function[STARTED] |
Cisco Certificate Change Notification[STARTED] | Cisco Certificate Change Notification[STARTED] |
Cisco Certificate Expiry Monitor[STARTED] | Cisco Certificate Expiry Monitor[STARTED] |
Cisco Change Credential Application[STARTED] | Cisco Change Credential Application[STARTED] |
Cisco CTIManager[STARTED] | Cisco CTIManager[STARTED] |
Cisco CTL Provider[STOPPED] Service Not Activated | Cisco CTL Provider[STARTED] |
Cisco Database Layer Monitor[STARTED] | Cisco Database Layer Monitor[STARTED] |
Cisco DHCP Monitor Service[STOPPED] Service Not Activated | Cisco DHCP Monitor Service[STOPPED] Service Not Activated |
Cisco Dialed Number Analyzer Server[STARTED] | Cisco Dialed Number Analyzer Server[STARTED] |
Cisco Dialed Number Analyzer[STARTED] | Cisco Dialed Number Analyzer[STARTED] |
Cisco DirSync[STOPPED] Service Not Activated | Cisco DirSync[STARTED] |
Cisco DRF Local[STARTED] | Cisco DRF Local[STARTED] |
Cisco DRF Master[STARTED] | Cisco DRF Master[STARTED] |
Cisco Extended Functions[STARTED] | Cisco Extended Functions[STARTED] |
Cisco Extension Mobility Application[STARTED] | Cisco Extension Mobility Application[STARTED] |
Cisco Extension Mobility[STARTED] | Cisco Extension Mobility[STARTED] |
Cisco IP Manager Assistant[STARTED] | Cisco IP Manager Assistant[STARTED] |
Cisco IP Voice Media Streaming App[STOPPED] Service Not Activated | Cisco IP Voice Media Streaming App[STARTED] |
Cisco License Manager[STARTED] | Cisco License Manager[STARTED] |
Cisco Log Partition Monitoring Tool[STARTED] | Cisco Log Partition Monitoring Tool[STARTED] |
Cisco Messaging Interface[STOPPED] Service Not Activated | Cisco Messaging Interface[STOPPED] Component is not running |
Cisco RIS Data Collector[STARTED] | Cisco RIS Data Collector[STARTED] |
Cisco RTMT Reporter Servlet[STARTED] | Cisco RTMT Reporter Servlet[STARTED] |
Cisco Serviceability Reporter[STARTED] | Cisco Serviceability Reporter[STARTED] |
Cisco SOAP - CallRecord Service[STARTED] | Cisco SOAP - CallRecord Service[STARTED] |
Cisco SOAP - CDRonDemand Service[STARTED] | Cisco SOAP - CDRonDemand Service[STARTED] |
Cisco Syslog Agent[STARTED] | Cisco Syslog Agent[STARTED] |
Cisco TAPS Service[STOPPED] Service Not Activated | Cisco TAPS Service[STARTED] |
Cisco Tftp[STARTED] | Cisco Tftp[STARTED] |
Cisco Tomcat Stats Servlet[STARTED] | Cisco Tomcat Stats Servlet[STARTED] |
Cisco Tomcat[STARTED] | Cisco Tomcat[STARTED] |
Cisco Trace Collection Service[STARTED] | Cisco Trace Collection Service[STARTED] |
Cisco Trace Collection Servlet[STARTED] | Cisco Trace Collection Servlet[STARTED] |
Cisco Trust Verification Service[STARTED] | Cisco Trust Verification Service[STARTED] |
Cisco Unified Mobile Voice Access Service[STOPPED] Service Not Activated | Cisco Unified Mobile Voice Access Service[STARTED] |
Cisco User Data Services[STARTED] | Cisco User Data Services[STARTED] |
Cisco UXL Web Service[STARTED] | Cisco UXL Web Service[STARTED] |
Cisco WebDialer Web Service[STOPPED] Service Not Activated | Cisco WebDialer Web Service[STARTED] |
Cluster Manager [STARTED] | Cluster Manager [STARTED] |
Getting list of all services | Getting list of all services |
Host Resources Agent[STARTED] | Host Resources Agent[STARTED] |
MIB2 Agent[STARTED] | MIB2 Agent[STARTED] |
Platform SOAP Services[STARTED] | Platform SOAP Services[STARTED] |
Service Manager is running | Service Manager is running |
SNMP Master Agent[STARTED] | SNMP Master Agent[STARTED] |
SOAP - Diagnostic Portal Database Service[STARTED] | SOAP - Diagnostic Portal Database Service[STARTED] |
SOAP -Log Collection APIs[STARTED] | SOAP -Log Collection APIs[STARTED] |
SOAP -Performance Monitoring APIs[STARTED] | SOAP -Performance Monitoring APIs[STARTED] |
SOAP -Real-Time Service APIs[STARTED] | SOAP -Real-Time Service APIs[STARTED] |
System Application Agent[STARTED] | System Application Agent[STARTED] |
System SSH [STARTED] | System SSH [STARTED] |
Column1 | Column1 |
Interesting, problem remains, that after reviewing plenty of jabber documentation, videos and training, I haven't find a single reference for this being supported on anything previous to CUCM 8.6(2).
And I'm watching a training video on directory integration this very moment and they always mention 8.6(2)+
You're free to try, it but I'm truly sorry to tell you, it won't be supported by us.
java
