Cisco UDS on CUCM 8.6.1.20000-1
Hi all,
I want to incorporate Directory Search on windows jabber without AD, I already Did it, using the UDS service on cisco, I've reading about this, It says this is only available en version 8.6.2+, I have that versión in my lab, but in production I haver the version 8.6.1.20000-1,
And on thar version (production) I haven´t installed presence yet,.
PLEASE! Tell me it works on 8.6.1.20000-1,
If it doest, could you please adviseme how to do an smooth and transparent upgrade to 8.6.2?
I hope it works please.
References:
https://wiklunds.wordpress.com/2012/04/23/setting-up-cisco-jabber-for-windows/
THANKS!
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
No, it doesn't
Cisco Unified Communications Manager User  Data Service UDS  is supported on Cisco Unified Communications  Manager version 8.6.2 or later.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_01000.html
You can go to any 8.6(2) releases from your version, just follow regular upgrade steps.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
5 REPLIES 5
Jaime Valencia
No, it doesn't
java
java
I didn't want to hear that answer, but thankyou any way.
I am going to install CUCM 8.6.1 n my lab hoping cisco is worng, I've alaready found incorrect documentation con cisco's site concerning support and capabilities features.
I'll tell you later,
Regards.
There's no error and I know for a fact it's not there, the service just doesn't exist on 8.6(1)X
System version: 8.6.1.10000-14
Cisco Trust Verification Service[STARTED]
Cisco UXL Web Service[STARTED]
Host Resources Agent[STARTED]
System version: 8.6.2.20000-2
Cisco Unified Mobile Voice Access Service[STARTED]
Cisco User Data Services[STARTED]
java
java
