721
Highlighted
Beginner
Cisco UMG 8.6.1 and Cisco SRST 8.8 or 9.0 compatibility?
Hi!
We have a customer who'd like to deploy 600 phones (3905) at their remote office. I can see that for classic SRST the max capacity for 3945 router is limited to 350 phones which is not enough in the current situation but for E-SRST the number is 1200. As it is know Cisco UMG is needed for deploying E-SRST. However the 3905 phone is supported starting with CME/SRST version 8.8. The latest version for Cisco UMG is 8.6.1 and I can't find any info about its compatibility with CME/SRST 8.8 or higher. Could somebody help me out and clear the situation? If it is not compatible then we'll have to persuade or customer to buy two 3945s.
Thanks!
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Where do you see that only 350 phones are supported for SRST? It is 1200:
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps10536/data_sheet_c78_553924.html
350 is for CME not SRST.
HTH,
Chris
2 REPLIES 2
Highlighted
Hall of Fame Master
HTH,
Chris
Highlighted
Thank you, Chris!
I've read this document a couple of times:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps2169/data_sheet_c78-678873.html
And everytime I read it I somehow thought that the column for E-SRST is actually for SRST - hence my confusion. You've saved my day!
Thanks again!
