Cisco Unified Border Element
preeve
Currently configuring a Cisco Unified Border Element on a Cisco 3945 router.  I am trying to configure a software MTP on the router and not use the UCM for the MTP.  Does telephony-service need to be turned up on the CUBE for this to work?
Senthil Kumar Sankar
The telephony-service is a mode in a router which has used as CME.
You can Hardware MTP in the router using DSP farming.
More info on the below link
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
Senthil
Senthil,
Thanks for the comment.  My questions was, does this require to turn on "telephony-service" to use the MTP on the router and not UCM.  I do not want to use hardware MTP, because I do not want to use DSPs.  I know using software MTP will utilize cycles from the router.  Here is a sample config I would like to do:
sccp ccm group 1
bind interface Loopback0
associate profile 1 register cube_mtp2
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions software 500
associate application sccp
Will this accomplish using the router only and not pointing it to the UCM.  Hope this clarifies.
