11-04-2011 06:01 AM - edited 03-16-2019 07:52 AM
Can anyone please help me to understand the exact difference between 'Reset' and 'Apply config' button on the CUCM 7.1.5 and which should be the correct button which applies to phone, gateway and gatekeepers.
Solved! Go to Solution.
11-04-2011 06:29 AM
Well, it takes a llittle bit to explain.
In previous versions of CUCM, they only have "Save" button on the admin page. As the name indicated, "Save" button saves configuration into database (hard disk).
However, saving configuraton to hard disk may or may not have immediate effect on the system functions. That's because most processes (programs) making decisions based on the data in computer memory (RAM).
Changing the data on hard drive does not necessary update the memory immeditately. There's a mechanism called "Change Notification" to ensure the update. The "Apply Config" button is a manual method to make changes take effect immediately.
Guess it's as clear as mud?
Michael
11-04-2011 06:11 AM
"Reset" means power off / power on the device. For IP phones, they'll go through the IP address allocation, firmware verification process.
"Apply config" does not trigger the above process.
Michael
11-04-2011 06:15 AM
Thanks for your reply Mike. So what is the exact function of Apply config button and in which situation/cases it should be used.
11-04-2011 06:29 AM
Michael
11-04-2011 06:38 AM
I got it. Thanks Mike
11-04-2011 06:41 AM
Hey Michael,
Great explanation here! You really made this process as clear as
any I've heard. (+5)
Cheers!
Rob
