Cisco Unified callmanager - Upgrade
c.carrion
 HI everybody,
where can i download these images?
Cisco callmanager
10.5(1.98000.387)
10.5(1.98000.476)
10.5(1.98050.102)
I need this image for fix a bug.(SSL Padding Oracle On Downgraded Legacy Encryption (POODLE) Vulnerability)
are they special images?
thanks
Jaime Valencia
Yes, they're not publicly available, reach TAC so they can post the fix, if there is one available
java
if this helps, please rate
Jaime Valencia
java
Aman Soi
Hi carrion,
Images available on cisco site for 10.5.1 are 10.5.1.10000-7.
https://software.cisco.com/download/release.html?mdfid=285963825&flowid=50402&softwareid=282074295&release=10.5(2)SU1&relind=AVAILABLE&rellifecycle=&reltype=latest
seems to be ES [Engineering Special ] version for resolving the bug. Open TAc case so that they can provide you.
regds,
aman
