Cisco Unified CM Administration Page on Publisher going really slow
Giovanni Ceci
Hey everyone,
We're having trouble with slowness for the Cisco Unified CM Administration (and Serviceability) web page on the Publisher node. We also have 2 Subscribers. One is working fine and we can access the Admin page without any slowness. Our other one has been taken down because we are moving it to another building in the next couple of days. In the RTMT, we are getting Database Replication errors because the other server is unreachable, but would this be a cause of the slowness of the Publisher CM Admin pages? The server is pingable with very little delay, and there's no duplex mismatches or collisions on the switch. Anyone have any ideas?
neocec
The web services are all Tomcat-based so, when you see performance issues, it's fairly common to restart Tomcat.  If you have taken a server offline and it's been a while, you may see some performance slowness as the servers are trying to detect if the old server has come back online.  However, after sometime - the server is "written off", if you will, and when you bring it back online then you may need to perform a repair or reset of dbreplication of the cluster.
Hailey
Please rate helpful posts!
kusatija
You can log into the publisher CLI with out any issues, right?
Try restarting the cisco tomcat services, by using the command:
utils service restart Cisco Tomcat
kunal
Hey Kunal, thanks for the reply.
I can log into the CLI just fine. I am not in the position right now to try it, and that's ok for now because this issue isn't service impacting. I will try it the moment I get the chance. But I'm curious to know why you think it might be a Tomcat service issue? Could you explain please?
neocec
Hailey
Thanks David! Your posts are always helpful! So I think you're right that the Publisher "writes off" the downed server because the Publisher is working fine this morning. I did not even have to restart the Tomcat services.
Thanks so much! Have a good day.
neocec
