Cisco Unified Enterprise Attendant Console with CME
Zohaib Hussain
I want to know if Enterprise Attendant Console v 8.6 can work with CME or not ?
Rob Huffman
Hi Zohaib,
Just to add a note to the great tips from Anand (+5 "A")
Product Specifications
Cisco  Unified Enterprise Attendant Console Version 8.6 is supported on Cisco  Unified Communications Manager Versions 7.1(5) through 8.6(2). Cisco  Unified Communications Manager Express is not supported. For Cisco  Unified Communications Manager Version 6.0 support, please use Cisco  Unified Enterprise Attendant Console Version 3.1.1.10.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/data_sheet_c78-520987.html
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
5 Replies 5
anchoudh
Level 9
Level 9
Hi Zohaib,
Please refer the section "Compatible Voice Products" in the below link.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/cme88spc.html
Hope it helps.
Anand
Pls rate helpful posts !!
I didn't find the attendant console there. Does this mean its not compatible ?
Rob Huffman
Hi Zohaib,
Cheers!
Rob
Thanks for the help guys.
Zohaib
Nilo Noguera
Level 5
Level 5
Q: Does the Attendant Console software work with Cisco Unified Communications Manager Express?
A: No, Cisco Unified Communications Manager Express does not support Attendant Console.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/97069-cmefaq.html#q7
Cisco Unified Communications Manager Express on Integrated Services Routers (CME-ISR) uses Cisco Unified CallConnectors which replaces the Arc Express Attendant Console for Cisco Unified CallManager Express.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-manager-express/end_of_life_notice_c51-705659.html
Thank you for the opportunity to assist you.
Best regards,
"Nilz"
Nilo Noguera - CCNA R&S
.:|:.:|:. Specialist, Cisco Global Virtual Engineering - Cisco Partner Help
http://www.cisco.com/web/partners/tools/ph.html
"niLz" Nilo Noguera Jr. | Specialist, Virtual Engineering - Partner Helpline Organization together we are the human network
