Highlighted
Enthusiast
Cisco Unified Mobility Advantage Blackberry only install
I am working on a CUMA install using only Blackberrys. From what I understand there is no configuration to be done on the ASA in this instance since BES will handle the proxy connections.
We are getting this error on the clients when they try to log in "Your MDS has been configured to deny SSL requests to servers that have certificates which are untrusted or expired.  Try using Device Side SSL which can be modified in your TLS Options.  Contact your system administrator with any questions."
I went through the process and created the security context and generated the CSR. We then generated a certificate and for some reason the Mobility server does not like the Certificate. Ive opened the p7b file and pasted into the CA response and it says the Certs invalid. Everywhere I've tried to actually import the cert says its invalid. We have tried txt, p7b, and cer files.
Can anybody point me into the right direction and let me know what I'm missing.
CUMA 7.1.3
BES 5
2 REPLIES 2
Highlighted
Did you resolve this issue ? How ? I am having exactely the same one with the CSR no been accepted by any CA I have been tryied in.
Beginner
Hi everyone,
Did you find an answer to this issue ? I have the same error for CUMA & Blackberry devices. Is the problem is coming from BES or CUCM (or CUMA) ?
Rémi
