03-20-2014 07:23 AM - edited 03-16-2019 10:11 PM
I am in need of a solution that enables people answer calls made to their office extensions on their mobile phones. Having found Cisco Unified Mobility Manager and Cisco Mobile Connect as a viable solution, I discovered that it has gone end-of-life. What is the replacement product or solution to achieve the same result or what are your suggestions on getting this done on their CUCM 7(1)2 cluster infrastructure? Thanks for the anticipated quick response.
Solved! Go to Solution.
03-20-2014 07:34 AM
Mobile connect is now built into CUCM, I belive this was done in version 6.0, so 7.1 includes it and does not require additional components.
Chris
03-20-2014 07:34 AM
Chris
