Cisco Unified Serviceability - Alarm & Trace
techguy
Level 4
Level 4
Can anyone tell me that how to access that Alarm and Trace reports which are enabled from Cisco Unified Serviceability webpage? I have enabled Trace on and checked all the concerned traces and alarm but from where i can vioe those. Thanks
Leonardo Santana
You cant set the traces on Serviceability and collect those from RTMT, follow the link bellow....
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Rate this if helps you
Leonardo Santana
*** Rate All Helpful Responses***
