Cisco Unified Wireless IP Phone 8821 EX feature
john.gizzi
Can I restrict the phone from dialing an outside number? For example. My organization uses a 4 digit numbering system for calling inside numbers. You have to dial a 9 then 1 and the area code and number to get to an outside line. Can I limit the phones to access inside extensions only?
Thanks!
pieterh
the short answer is YES,
CUCM has many options to control the dial capabilities of a device/phone
you can prepare configuration so a device can dial
- only a single number
- only 4 digit numbers,
- only local outside numbers
- international numbers
- etc
- or you can configure a phone so it can only answer incoming calls
you can prepare an hierarchical approach , and you can give access to additional features based on a PIN code, or on a logged in "user"
Jaime Valencia
Yes, CSS and partitions
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/dialplan.html#pgfId-1044276
Suggest you read the whole chapter prior to making any changes, you need a good understanding of dial plan to avoid introducing issues.
java
if this helps, please rate
