01-09-2013 11:37 AM - edited 03-16-2019 03:04 PM
Dear Friends,
I need to read cisco unity connection trace, please refer document, which I can use to learn reading unity connection traces, thanks
cheers,
Shaggy
01-09-2013 11:47 AM
Hi Raja,
Not sure if you've seen the following in the Troubleshooting Connection doc, but it can provide insight to the traces to enable based on the reported problem which can possible provide more direction on the trace you are attempting to read:
HTH,
Chris
01-10-2013 02:46 PM
Hi Chris,
Thank you very much, I cam across this document, I have taken the logs but I dont know, how to read them, please help, thanks
Cheers,
Shaggy
