06-06-2017 03:34 PM - edited 03-17-2019 10:31 AM
i have a unity connection 10.5.2.12901-1 Unrestricted and i try to
upgrade the system to version 11.5.1.su2 , I start the process
but i get an error that the upgrade were failed , so i look at the log file and saw that
in my active partition i have 100% and i thinking that it's my problem ,
here it the output of the command " show status " before and after upgrade failure
admin:show status
Host Name : cuc
Date : Tue Jun 6, 2017 14:27:37
Time Zone : xxxx
Locale : en_US.UTF-8
Product Ver : 10.5.2.12901-1 Unrestricted
Unified OS Version : 6.0.0.0-2
Uptime:
14:27:38 up 609 days, 3:31, 1 user, load average: 0.34, 0.59, 0.65
CPU Idle: 81.05% System: 05.26% User: 12.64%
IOWAIT: 00.00% IRQ: 00.00% Soft: 01.05%
Memory Total: 3925868K
Free: 123180K
Used: 3802688K
Cached: 666548K
Shared: 0K
Buffers: 16720K
Total Free Used
Disk/active 29705184K 6570924K 22832468K (78%)
Disk/inactive 29705120K 21647520K 7755808K (27%)
Disk/logging 103432216K 34911368K 63266768K (65%)
and here it after the upgrade failed admin:show status
Host Name : cuc
Date : Wed Jun 7, 2017 00:17:40
Time Zone : xxxx
Uptime:
00:17:42 up 7:07, 1 user, load average: 1.85, 0.92, 0.64
CPU Idle: 28.87% System: 08.25% User: 62.89%
IOWAIT: 00.00% IRQ: 00.00% Soft: 00.00%
Free: 153572K
Used: 3772296K
Cached: 830064K
Shared: 0K
Buffers: 38988K
Total Free Used
Disk/active 29705184K 0K 29704700K (100%)
Disk/inactive 29705120K 27838892K 1564436K (6%)
Disk/logging 103432216K 35019740K 63158396K (65%)
also get that error message
Java HotSpot(TM) Client VM warning: Insufficient space for shared memory file:
6808
Try using the -Djava.io.tmpdir= option to select an alternate temp location.
this is the first time i have this error and i have upgrade unity before and didn't get any error
any ideas how can i solved this problem ?
Yaniv
06-06-2017 05:14 PM
its a VM, give it more disk space
04-05-2018 01:15 PM
I am seeing the same issue when I try to upgrade from Unity Connection 11.0 to 11.5.
Did you resolve this problem? If yes please let me know how.
James
