Cisco Unity Express (CUE) Default Prompt Location or Download Inquiry
Andrew Chandler
Beginner
Beginner
If a CUE Default prompt is accidentally recorded over or erased how may it be recovered or downloaded versus a full factory default reset of the CUE?
Hythim Ali El Hadad
Frequent Contributor
you can tell your cue version so some one can attach it to you
i've CUE Version 8.0.5 and i need these default prompts urgently
thx in advance
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Which default prompt are you referring to ?
Recognize Your Peers
