ā04-16-2013 06:30 AM - edited ā03-16-2019 04:49 PM
hi all
please i want make sur from this license need :
The feature that i have by default on my CUE module ( SRE-300) :
1 * fl-cue-port 2
So what i need to know with the default license that i have ( fl-cue-port = 2 port / 2 session ) can i make 8 call simultanly from PSTN (to my 8 fxo port ) to my auto-attend or must purchase more license ? if yes what is it exactly ?
ā04-16-2013 06:35 AM
Hi.
Since you can make one call per port, with above license, you will be able to make only two calls to AA or VM.
Can you post show license status from cue CLI?
Carlo
ā04-16-2013 06:46 AM
when i put show license application status it give me that i have 2 port , 2 session , 15 mailbox
but my qustion it's now that i must purchase 3 fl-cue-port to have at final , 8port , 8 session , 15 mailbox to make 8 call simultanly to my AA ?
thanks
ā04-16-2013 07:05 AM
ā04-16-2013 07:12 AM
Hi Ahmed.
This link could help you.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_6/rel_notes/rel_notes86.html#wp296894
Carlo
ā04-16-2013 07:33 AM
thank you , but what i need is to make sure that to support 8 simultanly incomming call to my AA must purchase fl-cue-port not onother license ?
ā04-16-2013 07:50 AM
Hi.
From the above doc:
Note
You do not need to purchase IVR session licenses if you are only planning on using voicemail and auto attendant with basic IVR applications. IVR session licenses are only required if your application contains advanced IVR features such as email, fax, database access or VXML scripts."
So this means that the only license you need to add Auto Attendant Sessions, are port license.
Your Hardware supports up to 10 ports and count per license that you can buy is 2 (2 port each license).
Carlo
ā04-16-2013 08:13 AM
ok thanks for reply but just a last issue or let say a question , with my default license installed wich 1 * fl-cue-port can i support 8 simultanly incomming call to my AA without purchase license ?
thanks
best regard
ā04-16-2013 08:17 AM
Hi.
I gave an answer to this question in my first post.
You have only 2 ports license so you are able to make only two concurrent calls to your AA.
Carlo
