Cisco unity Express, SIP/2.0 486 Busy Here
joseriveros
I have a CME 2951 with CUE SM-SRE-700-K9, when a phone call is diverted to your voicemail the call is dropped and the debug gives the following error:
Sep 26 14:35:17.448: //6841/38BEACE5B4D5/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4000@10.51.43.3:5060 SIP/2.0
Via: SIP/2.0/UDP 10.51.43.2:5060;branch=z9hG4bK8CE196F
Remote-Party-ID: "test" <sip:6097@10.51.43.2>;party=calling;screen=no;privacy=off
From: "test" <sip:6097@10.51.43.2>;tag=4336CD6C-5A3
To: <sip:4000@10.51.43.3>
Date: Wed, 26 Sep 2012 14:35:17 GMT
Call-ID: 39C9661A-71E11E2-B4DAEDC7-5B43E6A4@10.51.43.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0952020197-0119411170-3033918919-1531176612
User-Agent: Cisco-SIPGateway/IOS-15.2.2.T1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1348670117
Contact: <sip:6097@10.51.43.2:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 184
v=0
o=CiscoSystemsSIP-GW-UserAgent 291 5795 IN IP4 10.51.43.2
s=SIP Call
c=IN IP4 10.51.43.2
t=0 0
m=audio 28500 RTP/AVP 0
c=IN IP4 10.51.43.2
a=rtpmap:0 PCMU/8000
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <sip:4000@10.51.43.3>;tag=ds2ac8de14
CSeq: 101 INVITE
Content-Length: 0
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 39C9661A-71E11E2-B4DAEDC7-5B43E6A4@10.51.43.2
Sent:
ACK sip:4000@10.51.43.3:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
10 Replies 10
paolo bevilacqua
Check on CUE CLI
'show license status application"
This was done and the CUE worked for a while and then stops working.
Can you please post the output of the command above
Was this ever resolved?
I have a similar issue.
same problem, but after see the license.
cue-172-30-253-252#  show license status application
voicemail disabled, ivr session quantity (4) is equal to or exceeds available ports (2)
ivr disabled, ivr session quantity (4) exceeds available ports (2)
i need to move out and modify the license on AIM-CUE
cue-172-30-253-252# license activate ivr sessions 2
Current license already active, count saved for use at next reload
cue-172-30-253-252# wr mem
cue-172-30-253-252# reload
Reloading the system will terminate all end user sessions.
Doing a reload will cause any unsaved configuration data to be lost.
Are you sure you want to reload? [confirm]
cue-172-30-253-252#
now after doing this the AIM-CUE still says the voicemail is disabled
cue-172-30-253-252# sho license status application
voicemail disabled, ivr session quantity (2) is equal to or exceeds available ports (2)
ivr enabled: 2 sessions
cue-172-30-253-252# license activate ivr sessions 1
Count is not a multiple of 2
cue-172-30-253-252# license activate ports 1
Now i'm lost... can't put down the ports to 1 but still the voicemail is disabled and ivr is not working....
really???? don't know what to do!
had a great day . best regards, and rate if you'll find this post useful
i found the way to fix this!!!
now my AIM-CUE works.
voicemail enabled: 6 ports, 2 sessions, 25 mailboxes
ivr enabled: 4 sessions
so as i summarize all data.
IVR-PORTS "MUST" be more than licensed IVR-SESSIONS.
then, Requested IVR-VM-MBX need just 2 IVR-PORTS to run.
there is the summary of IVR-PORTS on my AIM-CUE
4 IVR-PORTS used as IVR-SESSIONS
2 IVR-PORTS used for IVR-VM-MBX
6 Total IVR-PORTS
that's all and runs smooth!
best regards for all!
Thank you!
please rate if my post was useful for you...
best regards
Commands:
service-module# license activate ports 4
service-module# license activate ivr sessions 2
license activate voicemail mailboxes 25
reboot
show license in-use
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/CUELicensing_book/Using_CSL.html#wp1093737
Issue resolved, Thank you.
Zaheer Ul Hassan
