Cisco Unity Greeting/System call handler
Ajith Nayak
Dear all,
Hope you all are doing good !!
Folks, What is the exact bit rate/value/MB for a .wav file which can be uploaded in System call handler?
unfortunately I facing some issue as the file shared by our customer is not getting uploaded even its .wav :(
Hi Ajith, You can refer below table for exact format.
Property Value
Bit Rate 64kbps
Audio Sample Size
8 bit
Channels
1 (mono)
Audio Sample Rate 8khz
Audio Format CCITT U-law
Suresh Hudda
PCM encoding, 8 bits, 8 khz, mono. There are free tools, using one of them you can convert it to correct format.
Suresh
Hello Suresh,
So you mean below should be the format:
file type : mono
bit rate 8 or 64 kbps
audio sample rate 8khz
Property Value
Bit Rate 64kbps
Audio Sample Size
8 bit
Channels
1 (mono)
In case you need it this is a really easy way to do it as I converted hundreds of wav files from a legacy Nortel to Cisco supported wav using the following
1. Go here http://g711.org/
2. Select the first choice (Broadworks Classic)
3. Follow the rest of the steps.
