01-06-2020 12:32 PM
I am trying to setup (phone) notification devices in Unity. Once a voicemail is received the call will come from the Cisco Unity trunk. I am running into an issue because there is not a caller ID being sent with the call. Would someone be able to assist with an example of a dial-peer on my cube that is used based on the source trunk sending the call to the cube? Is there a better way to route this call and give it a caller ID? I am using SIP trunks from Unity > CUCM > Cube.
Thank you for your help!
01-06-2020 01:08 PM
Is the caller ID not working only for these notification calls or all calls to your system, i.e. direct DID calls to phones?
01-06-2020 02:22 PM
Calls are not working only for calls from this Unity Trunk > CUCM > Cube. All other calls inbound/outbound are working as expected and caller ID is working as expected.
01-06-2020 03:06 PM
Please provide "debug ccsip messages" output from CUBE, let us know what are the called, calling and the notification numbers.
