10-21-2016 10:45 PM - edited 03-17-2019 08:26 AM
Hi All
I have an issue going on in my environment where in users report that whenever from inside the cluster or internal user leave a message they hear that Mailbox is full, but when some external caller leaves a message there is no such problem.
Could someone please help me in finding out this issue and how we can resolve it?
Solved! Go to Solution.
10-21-2016 11:18 PM
Hi Rohit,
Refer to the below snippet:
Quotas are not enforced for messages left by outside callers if the “Full Mailbox Check for Outside Caller Messages” check box is not checked. This check box appears on the System Settings > Advanced > Conversations page.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsagx/8xcucsag190.html
1. Is this happening for a particular user or a group of users?
2. What is the message aging policy?
System Settings and click Message Aging Policy
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/administration/guide/2xcucsag190.html
3. What is the current disk usage?
Check from the output of show status & show hardware
4. Also, can you configure one user for PCA with web authentication password and ask him to delete some old messages to see if it helps? Below is the PCA URL:
https://10.106.117.133/ciscopca
5. Make sure the deleted folder is empty. Refer to the below discussion:
https://supportforums.cisco.com/discussion/11284961/unity-connection-empty-deleted-items-folder
Aseem
10-21-2016 11:18 PM
Hi Rohit,
Aseem
10-22-2016 01:03 AM
Thanks Aseem for your post again.
I will get back to you if required...Thanks a lot again.
10-22-2016 10:45 AM
Hi Rohit,
You are most welcome! Please rate the helpful posts if it helps you fix the issue.
Aseem
10-22-2016 08:25 PM
It helps ...Thanks :)
