07-26-2022 01:59 PM
Hello , does cisco offer another analog telephony device that would replace the VG204 gateways.? We would like to replace the ones that are curently being used since they no longer are supported. Thank you
07-26-2022 05:35 PM
According to the following link you should get the VG400 to replace VG204
https://www.cisco.com/c/en/us/products/collateral/unified-communications/vg-series-gateways/select-vg202xm-analog-voice-gateway-eol.html
John
Log in to Community
