01-27-2020 11:43 PM
we have the following setup and we try to achive a Clip No Screening/Diversion Header to our remote Destinations (mobile phones). Our SIP-Provider told us that they support the feature and that it is active on our SIP-Trunk.
And they gave us this as a help for setup: SipAddHeader(Diversion: <${ORIGEXTEN}@sipconnect.sipgate.de>) but this ist not for the "cisco world" this is only working for Asterisk in my opinion.
So maybe someone here can translate us this into cisco language for our Cube?
Anything else is working fine - the only thing what is not working ist the diversion header, so that we do not see the fallback trunk number (+498922222-0) but the original number of the caller (+492112345678).
If we call from an internal phone to another one and the remote destination is reached the number shows up correctly. But this is only working for internal calls and not for calls from external.
We use a Cisco 2951K9 with c2951-universalk9-mz.SPA.157-3.M5.bin IOS installed.
The Configuration looks like that:
voice-card 0 ! ! ! voice service voip ip address trusted list ipv4 XXXXX 255.255.255.255 ipv4 XXXXX 255.255.240.0 ipv4 XXXXX 255.255.240.0 ipv4 XXXXXX 255.255.224.0 mode border-element media statistics allow-connections sip to sip supplementary-service h450.12 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw h323 call service stop sip bind control source-interface GigabitEthernet0/1 bind media source-interface GigabitEthernet0/0 registrar server expires max 3600 min 1800 asserted-id ppi early-offer forced no silent-discard untrusted midcall-signaling passthru g729 annexb-all sip-profiles 1 ! voice class codec 1 codec preference 1 g711alaw codec preference 2 g722-64 codec preference 3 g711ulaw codec preference 4 g729r8 codec preference 5 g726r32 ! ! voice class sip-profiles 1 request REGISTER sip-header From modify "(<.*:)(.*@)" "<sip:2XXXX146t7@" request ANY sip-header From modify "(<.*:)(.*@)" "<sip:2XXXX146t7@" request INVITE sip-header To modify "(<.*:)(.*@)" "<sip:2XXXX46t7@" request INVITE sip-header Diversion modify "(<.*:)(.*@)" "<sip:2XXXX146t7@"- !this is our try to achive the function! voice translation-rule 3 rule 1 /^0/ /0049/ rule 2 /^0\(.*$\)/ /0049\1/ rule 4 /^11\(.*$\)/ /004911\1/ ! voice translation-rule 4 rule 1 /^\(78..$\)/ /493XX51139\1/ ! voice translation-rule 11 rule 1 /^/ // type unknown unknown rule 2 /^/ /49/ type national national rule 3 /^/ /0049/ type international international ! voice translation-rule 12 rule 1 /^493XX51139\(....$\)/ /\1/ ! ! voice translation-profile INCOMING translate calling 11 translate called 12 ! voice translation-profile OUTGOING translate calling 4 translate called 3 !
If we debug the SIP-Messages with debug ccsip messages we see the following in the "invite":
Jan 28 07:33:17.876: //14592/71E3E2000000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:+4917XX67XX72@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.16X.XX.254:5060;branch=z9hG4bKDF62337 From: "017XX69XX55" <sip:2XXXX146t7@217.10.68.150>;tag=E528F44-460 To: <sip:2XXXX146t7@217.10.68.150> Date: Tue, 28 Jan 2020 07:33:17 GMT Call-ID: 49325314-40D711EA-B746E80A-8109750A@192.16X.XX.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 1910759936-0000065536-0000000140-3360925888 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Timestamp: 1580196797 Contact: <sip:017XX69XX55@192.16X.XX.254:5060> Expires: 180 Allow-Events: telephone-event Proxy-Authorization: Digest username="2XXXX146t7",realm="sipconnect.sipgate.de",uri="sip:+4917XX7XX872@217.10.68.150:5060",response="1671b35c37f70979e2a6f79e5879e921",nonce="Xi/k6V4v473KfeUZJWYZl2D3Xh41A4mB",algorithm=md5 Max-Forwards: 64 P-Preferred-Identity: "0175XX9XX55" <sip:01752691155@192.16X.XX.254> Diversion: "Christoph XXXX"<sip:2XXXX146t7@192.16X.XX.200>;privacy=off;reason=follow-me;screen=yes Session-ID: 3bed17337ed9551aba3074f0fa5c2032;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 322 v=0 o=CiscoSystemsSIP-GW-UserAgent 7873 6417 IN IP4 192.16X.XX.254 s=SIP Call c=IN IP4 24.XXX.12.XX5 t=0 0 m=audio 16480 RTP/AVP 0 8 18 101 c=IN IP4 24.XXX.12.XX5 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20
So hopefully someone here can help us with the configuration of that.
Thank you very much in advance.
Solved! Go to Solution.
02-04-2020 01:52 AM
You need to modify your sip profile to have the valid DDI of all your extensions.
So if your extensions are 0175269XXXX
Then configure your PPI as follows
request INVITE sip-header P-Preferred-Identity modify "<sip:0175269(.*)@(.*)>" "<sip:49175269\1@\2>"
01-28-2020 07:59 AM
Hi Chris,
Do you want the diversion header to b e like this?
Diversion: "Christoph XXXX"<sip:2XXXX146t7@sipconnect.sipgate.de>
01-28-2020 09:40 AM
Hi Ayodeji,
no i want that it is look like this: SipAddHeader(Diversion: <${ORIGEXTEN}@sipconnect.sipgate.de>) in "cisco cube language" because this is the only thing what my provider gave me. What is that <${ORIGEXTEN}? And how can i set this in my cube?
Thanks for your quick reply.
01-29-2020 12:35 AM
This looks like a template...This is not what I think they want..
You need to clarify with them.. do they want this..
Diversion: <$XXXXX@sipconnect.sipgate.de>, where XXX is the originating extension?
01-29-2020 01:16 AM
I agree I think you need to clarify with the carrier as to which number should appear in each header. Can you post an example of what's currently been sent, if you want to keep your numbers confidential then overwrite with something like "XXX" for original calling number, "YYY" for your internal called number, with the divert in place and "ZZZ" for the final called number. So
XXX calls YYY
YYY is call forwarded to ZZZ
If I understand you correctly you want the final caller ZZZ to see the call as coming from XXX
So we need to know on that outgoing Invite, which headers should show YYY and which should show XXX
01-29-2020 10:04 AM
i have clarified with my carrier that the number must be the originating extension.
The debugs for the "INVITE" messages will follow tomorrow.
Thanks for your help.
01-30-2020 09:01 PM - edited 01-30-2020 09:05 PM
Hello together,
here are the debugs for the whole call (also the INVITE), i have done nothing with the phone numbers and my private ip space - my public IP is - MY PUBLIC IP.
The account number of my provider (22134146t7) is also not real but exat like the real one.
Jan 31 04:48:24.341: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ... Jan 31 04:48:26.757: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:49366511397811@192.168.83.254:5060 SIP/2.0 Record-Route: <sip:217.10.68.150;lr;ftag=as515c5d1b> Record-Route: <sip:172.20.40.8;lr> Record-Route: <sip:217.10.68.137;lr;ftag=as515c5d1b> Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKabe2.6e16c37dbd7ba2fc2171470ce5e65384.0 Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKabe2.44392bf2e18ac48dcea5c8a129bd78b1.0 Via: SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKabe2.d7b6c299821b7a9feb70f1f89d50293c.0 Via: SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK1aa7f7c7 Max-Forwards: 67 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de> Contact: <sip:01752691155@212.9.44.6:5060> Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de CSeq: 103 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Content-Type: application/sdp Content-Length: 438 v=0 o=root 760698569 760698570 IN IP4 212.9.44.6 s=sipgate VoIP GW c=IN IP4 212.9.44.174 t=0 0 m=audio 22184 RTP/AVP 8 0 3 97 18 112 101 a=silenceSupp:off - - - - a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:3 GSM/8000 a=rtpmap:97 iLBC/8000 a=rtpmap:18 G729/8000 a=rtpmap:112 G726-32/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:97 mode=30 a=fmtp:18 annexb=no a=fmtp:101 0-16 a=sendrecv a=rtcp:22185 a=ptime:20 Jan 31 04:48:26.761: //30096/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKabe2.6e16c37dbd7ba2fc2171470ce5e65384.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKabe2.44392bf2e18ac48dcea5c8a129bd78b1.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKabe2.d7b6c299821b7a9feb70f1f89d50293c.0,SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK1aa7f7c7 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de> Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de CSeq: 103 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 00000000000000000000000000000000;remote=c8bc479f6135556da489e31f503417e3 Content-Length: 0 Jan 31 04:48:26.765: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:7811@192.168.83.200:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C74988 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200> Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3236174494-1125847530-2999052298-2164880650 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1580446106 Contact: <sip:01752691155@192.168.83.254:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 66 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Session-ID: c8bc479f6135556da489e31f503417e3;remote=00000000000000000000000000000000 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 353 v=0 o=CiscoSystemsSIP-GW-UserAgent 9046 9635 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 192.168.83.254 t=0 0 m=audio 16924 RTP/AVP 8 0 18 98 101 c=IN IP4 192.168.83.254 a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:98 G726-32/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jan 31 04:48:26.769: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C74988 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200> Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 CSeq: 101 INVITE Allow-Events: presence Content-Length: 0 Jan 31 04:48:26.781: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C74988 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200>;tag=523495~badef395-9309-48d9-8bf8-030362ac44b2-23156887 Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 CSeq: 101 INVITE Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY Allow-Events: presence Server: Cisco-CUCM12.0 Supported: X-cisco-srtp-fallback Supported: Geolocation Session-ID: 00000000000000000000000000000000;remote=c8bc479f6135556da489e31f503417e3 P-Preferred-Identity: "Christoph" <sip:7811@192.168.83.200> Privacy: none Contact: <sip:7811@192.168.83.200:5060> Content-Length: 0 Jan 31 04:48:26.785: //30096/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKabe2.6e16c37dbd7ba2fc2171470ce5e65384.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKabe2.44392bf2e18ac48dcea5c8a129bd78b1.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKabe2.d7b6c299821b7a9feb70f1f89d50293c.0,SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK1aa7f7c7 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=1D2E5630-1A18 Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de CSeq: 103 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: "Christoph" <sip:7811@192.168.83.254> Contact: <sip:49366511397811@192.168.83.254:5060> Record-Route: <sip:217.10.68.150;lr;ftag=as515c5d1b>,<sip:172.20.40.8;lr>,<sip:217.10.68.137;lr;ftag=as515c5d1b> Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 00000000000000000000000000000000;remote=c8bc479f6135556da489e31f503417e3 Content-Length: 0 Jan 31 04:48:28.789: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:+491736749872@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c34a51b389f7 From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254> Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 Supported: timer,resource-priority,replaces Min-SE: 1800 User-Agent: Cisco-CUCM12.0 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 101 INVITE Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback Supported: Geolocation Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=MIXED Session-ID: c8bc479f6135556da489e31f503417e3;remote=00000000000000000000000000000000 Cisco-Guid: 3939728256-0000065536-0000000182-3360925888 Session-Expires: 1800 Diversion: "Christoph" <sip:7811@192.168.83.200>;reason=follow-me;privacy=off;screen=yes P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.200> Privacy: none Contact: <sip:01752691155@192.168.83.200:5060;transport=tcp> Max-Forwards: 65 Content-Type: application/sdp Content-Length: 312 v=0 o=CiscoSystemsCCM-SIP 523501 1 IN IP4 192.168.83.200 s=SIP Call c=IN IP4 192.168.83.254 b=TIAS:64000 b=AS:64 t=0 0 m=audio 16924 RTP/AVP 0 8 18 101 a=ptime:20 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 Jan 31 04:48:28.793: //30098/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c34a51b389f7 From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254> Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 00000000000000000000000000000000;remote=c8bc479f6135556da489e31f503417e3 Content-Length: 0 Jan 31 04:48:28.797: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C75FAB From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150> Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3939728256-0000065536-0000000182-3360925888 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1580446108 Contact: <sip:01752691155@192.168.83.254:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 64 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Diversion: "Christoph"<sip:7811@192.168.83.200>;privacy=off;reason=follow-me;screen=yes Session-ID: c8bc479f6135556da489e31f503417e3;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 322 v=0 o=CiscoSystemsSIP-GW-UserAgent 7164 6371 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY-PUBLIC-IP t=0 0 m=audio 16928 RTP/AVP 0 8 18 101 c=IN IP4 MY-PUBLIC-IP a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Jan 31 04:48:28.825: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 407 Proxy Authentication Required Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY-PUBLIC-IP;branch=z9hG4bK1C75FAB From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=ca40b14695a455acdff6b4fb6f6d0a8e.0c69 Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 CSeq: 101 INVITE Proxy-Authenticate: Digest realm="sipconnect.sipgate.de", nonce="XjOyyF4zsZyT2zHPTaFkUZl2SvRVBu7V" Content-Length: 0 Jan 31 04:48:28.825: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C75FAB From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=ca40b14695a455acdff6b4fb6f6d0a8e.0c69 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Session-ID: c8bc479f6135556da489e31f503417e3;remote=956e8ef1da00587a95dd0894b77ce437 Content-Length: 0 Jan 31 04:48:28.829: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C761F74 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150> Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3939728256-0000065536-0000000182-3360925888 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Timestamp: 1580446108 Contact: <sip:01752691155@192.168.83.254:5060> Expires: 180 Allow-Events: telephone-event Proxy-Authorization: Digest username="22134146t7",realm="sipconnect.sipgate.de",uri="sip:+491736749872@217.10.68.150:5060",response="06eb3f4b9c0542d4596fa658193ba22f",nonce="XjOyyF4zsZyT2zHPTaFkUZl2SvRVBu7V",algorithm=md5 Max-Forwards: 64 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Diversion: "Christoph"<sip:7811@192.168.83.200>;privacy=off;reason=follow-me;screen=yes Session-ID: c8bc479f6135556da489e31f503417e3;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 322 v=0 o=CiscoSystemsSIP-GW-UserAgent 7164 6371 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY-PUBLIC-IP t=0 0 m=audio 16928 RTP/AVP 0 8 18 101 c=IN IP4 MY-PUBLIC-IP a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Jan 31 04:48:28.881: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 trying -- your call is important to us Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY-PUBLIC-IP;branch=z9hG4bK1C761F74 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150> Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Content-Length: 0 Jan 31 04:48:30.769: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY-PUBLIC-IP;branch=z9hG4bK1C761F74 Record-Route: <sip:172.20.40.7;lr> Record-Route: <sip:217.10.68.150;lr;ftag=1D2E5E10-1395> From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=as26c7fc96 Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Contact: <sip:190049D1241736749872@217.116.117.5:5060> Content-Length: 0 Jan 31 04:48:30.773: //30098/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 180 Ringing Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c34a51b389f7 From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254>;tag=1D2E65C8-16D9 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: <sip:+491736749872@192.168.83.254> Contact: <sip:190049D1241736749872@192.168.83.254:5060;transport=tcp> Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 Content-Length: 0 Jan 31 04:48:30.985: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 183 Session Progress Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY-PUBLIC-IP;branch=z9hG4bK1C761F74 Record-Route: <sip:172.20.40.7;lr> Record-Route: <sip:217.10.68.150;lr;ftag=1D2E5E10-1395> From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=as26c7fc96 Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Contact: <sip:190049D1241736749872@217.116.117.5:5060> Content-Type: application/sdp Content-Length: 345 v=0 o=root 1396495072 1396495072 IN IP4 217.116.117.5 s=sipgate VoIP GW c=IN IP4 217.10.77.146 t=0 0 m=audio 28558 RTP/AVP 8 0 18 101 a=silenceSupp:off - - - - a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:18 annexb=no a=fmtp:101 0-16 a=sendrecv a=rtcp:28559 a=ptime:20 Jan 31 04:48:30.989: //30098/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 183 Session Progress Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c34a51b389f7 From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254>;tag=1D2E65C8-16D9 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: <sip:+491736749872@192.168.83.254> Contact: <sip:190049D1241736749872@192.168.83.254:5060;transport=tcp> Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 253 v=0 o=CiscoSystemsSIP-GW-UserAgent 1181 7556 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 192.168.83.254 t=0 0 m=audio 16926 RTP/AVP 8 101 c=IN IP4 192.168.83.254 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jan 31 04:48:31.117: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY-PUBLIC-IP;branch=z9hG4bK1C761F74 Record-Route: <sip:172.20.40.7;lr> Record-Route: <sip:217.10.68.150;lr;ftag=1D2E5E10-1395> From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=as26c7fc96 Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Contact: <sip:190049D1241736749872@217.116.117.5:5060> Content-Type: application/sdp Content-Length: 345 v=0 o=root 1396495072 1396495073 IN IP4 217.116.117.5 s=sipgate VoIP GW c=IN IP4 217.10.77.146 t=0 0 m=audio 28558 RTP/AVP 8 0 18 101 a=silenceSupp:off - - - - a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:18 annexb=no a=fmtp:101 0-16 a=sendrecv a=rtcp:28559 a=ptime:20 Jan 31 04:48:31.121: //30098/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c34a51b389f7 From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254>;tag=1D2E65C8-16D9 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: <sip:+491736749872@192.168.83.254> Contact: <sip:+491736749872@192.168.83.254:5060;transport=tcp> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 Supported: timer Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 253 v=0 o=CiscoSystemsSIP-GW-UserAgent 1181 7556 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 192.168.83.254 t=0 0 m=audio 16926 RTP/AVP 8 101 c=IN IP4 192.168.83.254 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jan 31 04:48:31.121: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:190049D1241736749872@217.116.117.5:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C772667 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=as26c7fc96 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 Route: <sip:217.10.68.150;lr;ftag=1D2E5E10-1395>,<sip:172.20.40.7;lr> Max-Forwards: 70 CSeq: 102 ACK Proxy-Authorization: Digest username="22134146t7",realm="sipconnect.sipgate.de",uri="sip:+491736749872@217.10.68.150:5060",response="06eb3f4b9c0542d4596fa658193ba22f",nonce="XjOyyF4zsZyT2zHPTaFkUZl2SvRVBu7V",algorithm=md5 Allow-Events: telephone-event Content-Length: 0 Jan 31 04:48:31.125: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:+491736749872@192.168.83.254:5060;transport=tcp SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c34bd44fe54 From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254>;tag=1D2E65C8-16D9 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 User-Agent: Cisco-CUCM12.0 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: presence Privacy: none Content-Length: 0 Jan 31 04:48:31.133: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C74988 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200>;tag=523495~badef395-9309-48d9-8bf8-030362ac44b2-23156887 Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 CSeq: 101 INVITE Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY Allow-Events: presence Supported: replaces Server: Cisco-CUCM12.0 Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=MIXED Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uas Require: timer Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 P-Preferred-Identity: "Christoph" <sip:7811@192.168.83.200> Privacy: none Contact: <sip:7811@192.168.83.200:5060> Content-Type: application/sdp Content-Length: 241 v=0 o=CiscoSystemsCCM-SIP 523495 1 IN IP4 192.168.83.200 s=SIP Call c=IN IP4 192.168.83.254 b=TIAS:64000 b=AS:64 t=0 0 m=audio 16926 RTP/AVP 8 101 a=ptime:20 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 Jan 31 04:48:31.137: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:7811@192.168.83.200:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C78FD1 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200>;tag=523495~badef395-9309-48d9-8bf8-030362ac44b2-23156887 Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Session-ID: c8bc479f6135556da489e31f503417e3;remote=a6c14d1319955c388ab207ffef7f0005 Content-Length: 0 Jan 31 04:48:31.141: //30096/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKabe2.6e16c37dbd7ba2fc2171470ce5e65384.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKabe2.44392bf2e18ac48dcea5c8a129bd78b1.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKabe2.d7b6c299821b7a9feb70f1f89d50293c.0,SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK1aa7f7c7 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=1D2E5630-1A18 Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de CSeq: 103 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: "Christoph" <sip:7811@192.168.83.254> Contact: <sip:49366511397811@192.168.83.254:5060> Record-Route: <sip:217.10.68.150;lr;ftag=as515c5d1b>,<sip:172.20.40.8;lr>,<sip:217.10.68.137;lr;ftag=as515c5d1b> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 Supported: timer Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 194 v=0 o=CiscoSystemsSIP-GW-UserAgent 4633 997 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY-PUBLIC-IP t=0 0 m=audio 16922 RTP/AVP 8 c=IN IP4 MY-PUBLIC-IP a=rtpmap:8 PCMA/8000 a=ptime:20 Jan 31 04:48:31.169: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:49366511397811@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKabe2.0f143a4bccfd321925b1e9ce480be4c1.0 Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKabe2.282b31287103176291178da1ae564515.0 Via: SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKabe2.1c4b85c874a47aed66a544bc57c72a4e.0 Via: SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK29e744ad Max-Forwards: 67 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=1D2E5630-1A18 Contact: <sip:01752691155@212.9.44.6:5060> Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de CSeq: 103 ACK Content-Length: 0 Jan 31 04:48:33.738: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: OPTIONS sip:192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c3544b16d127 From: <sip:192.168.83.200>;tag=1856700166 To: <sip:192.168.83.254> Date: Fri, 31 Jan 2020 04:48:33 GMT Call-ID: edce6c00-e331b1a1-1a23b-c853a8c0@192.168.83.200 User-Agent: Cisco-CUCM12.0 CSeq: 101 OPTIONS Contact: <sip:192.168.83.200:5060;transport=tcp> Max-Forwards: 0 Content-Length: 0 Jan 31 04:48:33.742: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c3544b16d127 From: <sip:192.168.83.200>;tag=1856700166 To: <sip:192.168.83.254>;tag=1D2E715C-176F Date: Fri, 31 Jan 2020 04:48:33 GMT Call-ID: edce6c00-e331b1a1-1a23b-c853a8c0@192.168.83.200 Server: Cisco-SIPGateway/IOS-15.7.3.M5 CSeq: 101 OPTIONS Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Accept: application/sdp Supported: 100rel,timer,resource-priority,replaces,sdp-anat Content-Type: application/sdp Content-Length: 376 v=0 o=CiscoSystemsSIP-GW-UserAgent 1719 9356 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY-PUBLIC-IP t=0 0 m=audio 0 RTP/AVP 18 0 8 9 4 2 15 c=IN IP4 MY-PUBLIC-IP m=image 0 udptl t38 c=IN IP4 MY-PUBLIC-IP a=T38FaxVersion:0 a=T38MaxBitRate:9600 a=T38FaxRateManagement:transferredTCF a=T38FaxMaxBuffer:200 a=T38FaxMaxDatagram:320 a=T38FaxUdpEC:t38UDPRedundancy Jan 31 04:48:35.626: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: BYE sip:49366511397811@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bK7be2.c52f818bd36fa84936005d0fe2306e33.0 Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bK7be2.0dd2fd5499652edce8bf9ce2fda237b0.0 Via: SIP/2.0/UDP 217.10.68.137;branch=z9hG4bK7be2.2fd542f61e8ff5c468f38ef398b0903a.0 Via: SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK66a5ffee Max-Forwards: 67 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=1D2E5630-1A18 Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de CSeq: 104 BYE Reason: Q.850;cause=16 Content-Length: 0 Jan 31 04:48:35.630: //30096/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bK7be2.c52f818bd36fa84936005d0fe2306e33.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bK7be2.0dd2fd5499652edce8bf9ce2fda237b0.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bK7be2.2fd542f61e8ff5c468f38ef398b0903a.0,SIP/2.0/UDP 212.9.44.6:5060;branch=z9hG4bK66a5ffee From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as515c5d1b To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=1D2E5630-1A18 Date: Fri, 31 Jan 2020 04:48:35 GMT Call-ID: 3fac1308647e0b3c7fc7f7772110b074@sipconnect.sipgate.de Server: Cisco-SIPGateway/IOS-15.7.3.M5 CSeq: 104 BYE Reason: Q.850;cause=16 P-RTP-Stat: PS=225,OS=36000,PR=204,OR=32640,PL=0,JI=0,LA=0,DU=4 Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 Content-Length: 0 Jan 31 04:48:35.630: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Sent: BYE sip:7811@192.168.83.200:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C793FB From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200>;tag=523495~badef395-9309-48d9-8bf8-030362ac44b2-23156887 Date: Fri, 31 Jan 2020 04:48:26 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Max-Forwards: 70 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Timestamp: 1580446115 CSeq: 102 BYE Reason: Q.850;cause=16 P-RTP-Stat: PS=204,OS=32640,PR=225,OR=36000,PL=0,JI=0,LA=0,DU=4 Session-ID: c8bc479f6135556da489e31f503417e3;remote=a6c14d1319955c388ab207ffef7f0005 Content-Length: 0 Jan 31 04:48:35.634: //30097/C0E41A9EB2C1/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C793FB From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5620-131 To: <sip:22134146t7@192.168.83.200>;tag=523495~badef395-9309-48d9-8bf8-030362ac44b2-23156887 Date: Fri, 31 Jan 2020 04:48:35 GMT Call-ID: C0E552EE-431B11EA-B2C7E80A-8109750A@192.168.83.254 Server: Cisco-CUCM12.0 CSeq: 102 BYE Content-Length: 0 Jan 31 04:48:35.634: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: BYE sip:+491736749872@192.168.83.254:5060;transport=tcp SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c35536ad06e From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254>;tag=1D2E65C8-16D9 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 User-Agent: Cisco-CUCM12.0 Max-Forwards: 70 Privacy: none P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.200> CSeq: 102 BYE Reason: Q.850;cause=16 Session-ID: c8bc479f6135556da489e31f503417e3;remote=a6c14d1319955c388ab207ffef7f0005 Content-Length: 0 Jan 31 04:48:35.638: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1c35536ad06e From: "01752691155" <sip:01752691155@192.168.83.200>;tag=523501~badef395-9309-48d9-8bf8-030362ac44b2-23156888 To: <sip:+491736749872@192.168.83.254>;tag=1D2E65C8-16D9 Date: Fri, 31 Jan 2020 04:48:35 GMT Call-ID: ead37b80-e331b19c-1a237-c853a8c0@192.168.83.200 Server: Cisco-SIPGateway/IOS-15.7.3.M5 CSeq: 102 BYE Reason: Q.850;cause=16 P-RTP-Stat: PS=232,OS=37120,PR=204,OR=32640,PL=0,JI=0,LA=0,DU=4 Session-ID: a6c14d1319955c388ab207ffef7f0005;remote=c8bc479f6135556da489e31f503417e3 Content-Length: 0 Jan 31 04:48:35.638: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Sent: BYE sip:190049D1241736749872@217.116.117.5:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK1C7A20CA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=as26c7fc96 Date: Fri, 31 Jan 2020 04:48:28 GMT Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Max-Forwards: 70 Route: <sip:217.10.68.150;lr;ftag=1D2E5E10-1395>,<sip:172.20.40.7;lr> P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Timestamp: 1580446115 CSeq: 103 BYE Proxy-Authorization: Digest username="22134146t7",realm="sipconnect.sipgate.de",uri="sip:190049D1241736749872@217.116.117.5:5060",response="b5d863993d188ef62e7138c0af8e463d",nonce="XjOyyF4zsZyT2zHPTaFkUZl2SvRVBu7V",algorithm=md5 Reason: Q.850;cause=16 P-RTP-Stat: PS=204,OS=32640,PR=232,OR=37120,PL=0,JI=0,LA=0,DU=4 Session-ID: c8bc479f6135556da489e31f503417e3;remote=a6c14d1319955c388ab207ffef7f0005 Content-Length: 0 Jan 31 04:48:35.666: //30099/EAD37B800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY-PUBLIC-IP;branch=z9hG4bK1C7A20CA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=1D2E5E10-1395 To: <sip:22134146t7@217.10.68.150>;tag=as26c7fc96 Call-ID: C21B6986-431B11EA-B2CDE80A-8109750A@192.168.83.254 CSeq: 103 BYE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Content-Length: 0 u Jan 31 04:48:38.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: MY-PUBLIC-IP
01-31-2020 03:23 AM
To make sure we're clear it appears that in this example ...
01752691155 is the original caller
He called 0049366511397811 which internally routes to extension 7811
7811 diverts to +491736749872
And as I understand it your problem relates to what the final called party +491736749872 sees as a the calling number.
Is that all correct? If so then what does the final called party see, and what do you want them to see.
Was that debug taken with the configuration exactly as shown before? The reason I ask it that your profile does not appear to have affected the outgoing Diversion header which still shows the number 7811 as sent by CUCM.
01-31-2020 07:11 AM
Yes that is all correct.
The final called party see: +4936651139780 (fallback number from our SIP-TRUNK) and i want them to see +491752691155 (original caller).
No the debug was not made with the config shown above. We have now brought the config back up to the state from above.
Do we need another debug?
Thank you very much for your help.
01-31-2020 08:09 AM
Yes, paste up another debug. If I follow your configuration correctly you should see the number in P-Asserted-Identity changed by your SIP profile.
02-01-2020 12:03 AM
Here is another debug with the config from above:
Feb 1 07:59:07.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:49366511397811@192.168.83.254:5060 SIP/2.0 Record-Route: <sip:217.10.68.150;lr;ftag=as2555b591> Record-Route: <sip:172.20.40.8;lr> Record-Route: <sip:217.10.68.137;lr;ftag=as2555b591> Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0 Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0 Via: SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKc1a4.58f8500896bf3e3d60ed149fd4ab5bd0.0 Via: SIP/2.0/UDP 217.10.67.11:5060;branch=z9hG4bK2e76d6c4 Max-Forwards: 67 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de> Contact: <sip:01752691155@217.10.67.11:5060> Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Content-Type: application/sdp Content-Length: 442 v=0 o=root 2036942571 2036942572 IN IP4 217.10.67.11 s=sipgate VoIP GW c=IN IP4 212.9.44.164 t=0 0 m=audio 16788 RTP/AVP 8 0 3 97 18 112 101 a=silenceSupp:off - - - - a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:3 GSM/8000 a=rtpmap:97 iLBC/8000 a=rtpmap:18 G729/8000 a=rtpmap:112 G726-32/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:97 mode=30 a=fmtp:18 annexb=no a=fmtp:101 0-16 a=sendrecv a=rtcp:16789 a=ptime:20 Feb 1 07:59:07.256: //36132/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKc1a4.58f8500896bf3e3d60ed149fd4ab5bd0.0,SIP/2.0/UDP 217.10.67.11:5060;branch=z9hG4bK2e76d6c4 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de> Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 00000000000000000000000000000000;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 07:59:07.260: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:7811@192.168.77.201:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:22134146t7@192.168.77.201> Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 2388586559-1140789738-2310203402-2164880650 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1580543947 Contact: <sip:01752691155@192.168.83.254:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 66 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 352 Cisco2951# Cisco2951# Cisco2951#v=0 o=CiscoSystemsSIP-GW-UserAgent 186 1020 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 192.168.83.254 t=0 0 m=audio 17000 RTP/AVP 8 0 18 98 101 c=IN IP4 192.168.83.254 a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:98 G726-32/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Feb 1 07:59:07.308: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:22134146t7@192.168.77.201> Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 CSeq: 101 INVITE Allow-Events: presence Content-Length: 0 Feb 1 07:59:07.356: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:22134146t7@192.168.77.201>;tag=111403~badef395-9309-48d9-8bf8-030362ac44b2-55015452 Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 CSeq: 101 INVITE Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY Allow-Events: presence Server: Cisco-CUCM12.0 Supported: X-cisco-srtp-fallback Supported: Geolocation Session-ID: 00000000000000000000000000000000;remote=5ef89e0f7af051a486054e00b7492dfd P-Preferred-Identity: "Christoph" <sip:7811@192.168.77.201> Privacy: none Contact: <sip:7811@192.168.77.201:5060> Content-Length: 0 Feb 1 07:59:07.360: //36132/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKc1a4.58f8500896bf3e3d60ed149fd4ab5bd0.0,SIP/2.0/UDP 217.10.67.11:5060;branch=z9hG4bK2e76d6c4 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=23031DE8-43D Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: "Christoph" <sip:7811@192.168.83.254> Contact: <sip:49366511397811@192.168.83.254:5060> Record-Route: <sip:217.10.68.150;lr;ftag=as2555b591>,<sip:172.20.40.8;lr>,<sip:217.10.68.137;lr;ftag=as2555b591> Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 00000000000000000000000000000000;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 08:59:08 CET: %FW-6-DROP_PKT: Dropping tcp session 93.174.93.33:59487 MY PUBLIC IP:33911 on zone-pair Internet_to_Router class class-default due to DROP action found in policy-map with ip ident 34820 Feb 1 07:59:09.373: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:+491736749872@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254> Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 Supported: timer,resource-priority,replaces Min-SE: 1800 User-Agent: Cisco-CUCM12.0 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 101 INVITE Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback Supported: Geolocation Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=MIXED Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Cisco-Guid: 3097184768-0000065536-0000000190-3360925888 Session-Expires: 1800 Diversion: "Christoph" <sip:7811@192.168.83.200>;reason=follow-me;privacy=off;screen=yes P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.200> Privacy: none Contact: <sip:01752691155@192.168.83.200:5060;transport=tcp> Max-Forwards: 65 Content-Type: application/sdp Content-Length: 312 v=0 o=CiscoSystemsCCM-SIP 551504 1 IN IP4 192.168.83.200 s=SIP Call c=IN IP4 192.168.83.254 b=TIAS:64000 b=AS:64 t=0 0 m=audio 17000 RTP/AVP 0 8 18 101 a=ptime:20 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 Feb 1 07:59:09.381: //36134/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254> Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 00000000000000000000000000000000;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 07:59:09.385: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220A62F From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150> Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3097184768-0000065536-0000000190-3360925888 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1580543949 Contact: <sip:01752691155@192.168.83.254:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 64 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Diversion: "Christoph"<sip:2XXXX146t7@192.168.83.200>;privacy=off;reason=follow-me;screen=yes Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 322 v=0 o=CiscoSystemsSIP-GW-UserAgent 9085 3972 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY PUBLIC IP t=0 0 m=audio 17004 RTP/AVP 0 8 18 101 c=IN IP4 MY PUBLIC IP a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Feb 1 07:59:09.413: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 407 Proxy Authentication Required Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY PUBLIC IP;branch=z9hG4bK220A62F From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=ca40b14695a455acdff6b4fb6f6d0a8e.0c69 Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 101 INVITE Proxy-Authenticate: Digest realm="sipconnect.sipgate.de", nonce="XjUw+V41L83/VF5Iwn9ic4GKqjhGrFLY" Content-Length: 0 Feb 1 07:59:09.413: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220A62F From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=ca40b14695a455acdff6b4fb6f6d0a8e.0c69 Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=c40b8e41191b5d6f8553d73f4128be28 Content-Length: 0 Feb 1 07:59:09.413: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220BC34 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150> Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3097184768-0000065536-0000000190-3360925888 User-Agent: Cisco-SIPGateway/IOS-15.7.3.M5 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Timestamp: 1580543949 Contact: <sip:01752691155@192.168.83.254:5060> Expires: 180 Allow-Events: telephone-event Proxy-Authorization: Digest username="22134146t7",realm="sipconnect.sipgate.de",uri="sip:+491736749872@217.10.68.150:5060",response="4fffd602e51734c980c654cdc48500d3",nonce="XjUw+V41L83/VF5Iwn9ic4GKqjhGrFLY",algorithm=md5 Max-Forwards: 64 P-Preferred-Identity: "01752691155" <sip:01752691155@192.168.83.254> Diversion: "Christoph"<sip:2XXXX146t7@192.168.83.200>;privacy=off;reason=follow-me;screen=yes Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 322 v=0 o=CiscoSystemsSIP-GW-UserAgent 9085 3972 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY PUBLIC IP t=0 0 m=audio 17004 RTP/AVP 0 8 18 101 c=IN IP4 MY PUBLIC IP a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Feb 1 07:59:09.469: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 trying -- your call is important to us Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY PUBLIC IP;branch=z9hG4bK220BC34 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150> Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Content-Length: 0 Feb 1 07:59:11.413: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ... Feb 1 07:59:11.929: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: OPTIONS sip:192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.77.201:5060;branch=z9hG4bK1ad954bdef367 From: <sip:192.168.77.201>;tag=1609743988 To: <sip:192.168.83.254> Date: Sat, 01 Feb 2020 07:59:11 GMT Call-ID: b9cc7700-e3512fcf-1acde-c94da8c0@192.168.77.201 User-Agent: Cisco-CUCM12.0 CSeq: 101 OPTIONS Contact: <sip:192.168.77.201:5060;transport=tcp> Max-Forwards: 0 Content-Length: 0 Feb 1 07:59:11.929: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 192.168.77.201:5060;branch=z9hG4bK1ad954bdef367 From: <sip:192.168.77.201>;tag=1609743988 To: <sip:192.168.83.254>;tag=23032FC0-F5F Date: Sat, 01 Feb 2020 07:59:11 GMT Call-ID: b9cc7700-e3512fcf-1acde-c94da8c0@192.168.77.201 Server: Cisco-SIPGateway/IOS-15.7.3.M5 CSeq: 101 OPTIONS Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Accept: application/sdp Supported: 100rel,timer,resource-priority,replaces,sdp-anat Content-Type: application/sdp Content-Length: 376 v=0 o=CiscoSystemsSIP-GW-UserAgent 7585 5115 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY PUBLIC IP t=0 0 m=audio 0 RTP/AVP 18 0 8 9 4 2 15 c=IN IP4 MY PUBLIC IP m=image 0 udptl t38 c=IN IP4 MY PUBLIC IP a=T38FaxVersion:0 a=T38MaxBitRate:9600 a=T38FaxRateManagement:transferredTCF a=T38FaxMaxBuffer:200 a=T38FaxMaxDatagram:320 a=T38FaxUdpEC:t38UDPRedundancy Feb 1 07:59:12.137: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY PUBLIC IP;branch=z9hG4bK220BC34 Record-Route: <sip:172.20.40.7;lr> Record-Route: <sip:217.10.68.150;lr;ftag=230325CC-1921> From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=as6a0d7701 Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Contact: <sip:190049D1241736749872@217.10.67.11:5060> Content-Length: 0 Feb 1 07:59:12.141: //36134/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 180 Ringing Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254>;tag=23033090-213D Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: <sip:+491736749872@192.168.83.254> Contact: <sip:190049D1241736749872@192.168.83.254:5060;transport=tcp> Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 2ef0fca8f9245695ac8b187badc32b63;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 07:59:12.141: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 183 Session Progress Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY PUBLIC IP;branch=z9hG4bK220BC34 Record-Route: <sip:172.20.40.7;lr> Record-Route: <sip:217.10.68.150;lr;ftag=230325CC-1921> From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=as6a0d7701 Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Contact: <sip:190049D1241736749872@217.10.67.11:5060> Content-Type: application/sdp Content-Length: 343 v=0 o=root 1459374857 1459374857 IN IP4 217.10.67.11 s=sipgate VoIP GW c=IN IP4 212.9.44.186 t=0 0 m=audio 23522 RTP/AVP 8 0 18 101 a=silenceSupp:off - - - - a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:18 annexb=no a=fmtp:101 0-16 a=sendrecv a=rtcp:23523 a=ptime:20 Feb 1 07:59:12.145: //36134/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 183 Session Progress Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254>;tag=23033090-213D Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event P-Preferred-Identity: <sip:+491736749872@192.168.83.254> Contact: <sip:190049D1241736749872@192.168.83.254:5060;transport=tcp> Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.7.3.M5 Session-ID: 2ef0fca8f9245695ac8b187badc32b63;remote=5ef89e0f7af051a486054e00b7492dfd Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 252 v=0 o=CiscoSystemsSIP-GW-UserAgent 220 9067 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 192.168.83.254 t=0 0 m=audio 17002 RTP/AVP 8 101 c=IN IP4 192.168.83.254 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Feb 1 07:59:13.237: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: OPTIONS sip:192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae238647b18 From: <sip:192.168.83.200>;tag=492971018 To: <sip:192.168.83.254> Date: Sat, 01 Feb 2020 07:59:13 GMT Call-ID: bafda400-e3512fd1-1b8cd-c853a8c0@192.168.83.200 User-Agent: Cisco-CUCM12.0 CSeq: 101 OPTIONS Contact: <sip:192.168.83.200:5060;transport=tcp> Max-Forwards: 0 Content-Length: 0 Feb 1 07:59:13.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae238647b18 From: <sip:192.168.83.200>;tag=492971018 To: <sip:192.168.83.254>;tag=230334DC-239A Date: Sat, 01 Feb 2020 07:59:13 GMT Call-ID: bafda400-e3512fd1-1b8cd-c853a8c0@192.168.83.200 Server: Cisco-SIPGateway/IOS-15.7.3.M5 CSeq: 101 OPTIONS Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Accept: application/sdp Supported: 100rel,timer,resource-priority,replaces,sdp-anat Content-Type: application/sdp Content-Length: 376 v=0 o=CiscoSystemsSIP-GW-UserAgent 6441 9159 IN IP4 192.168.83.254 s=SIP Call c=IN IP4 MY PUBLIC IP t=0 0 m=audio 0 RTP/AVP 18 0 8 9 4 2 15 c=IN IP4 MY PUBLIC IP m=image 0 udptl t38 c=IN IP4 MY PUBLIC IP a=T38FaxVersion:0 a=T38MaxBitRate:9600 a=T38FaxRateManagement:transferredTCF a=T38FaxMaxBuffer:200 a=T38FaxMaxDatagram:320 a=T38FaxUdpEC:t38UDPRedundancy Feb 1 07:59:13.977: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: CANCEL sip:49366511397811@192.168.83.254:5060 SIP/2.0 Record-Route: <sip:217.10.68.150;lr;ftag=as2555b591> Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0 Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0 Max-Forwards: 67 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de> Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 CANCEL Content-Length: 0 Feb 1 07:59:13.981: //36132/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de> Date: Sat, 01 Feb 2020 07:59:13 GMT Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 CANCEL Session-ID: 00000000000000000000000000000000;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 07:59:13.981: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: CANCEL sip:7811@192.168.77.201:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:7811@192.168.77.201> Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 CSeq: 101 CANCEL Max-Forwards: 70 Timestamp: 1580543953 Reason: Q.850;cause=16 Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Content-Length: 0 Feb 1 07:59:13.981: //36132/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 487 Request Cancelled Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKc1a4.58f8500896bf3e3d60ed149fd4ab5bd0.0,SIP/2.0/UDP 217.10.67.11:5060;branch=z9hG4bK2e76d6c4 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=23031DE8-43D Date: Sat, 01 Feb 2020 07:59:13 GMT Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.7.3.M5 Reason: Q.850;cause=16 Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Content-Length: 0 Feb 1 07:59:14.009: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:49366511397811@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/UDP 217.10.68.150;branch=z9hG4bKc1a4.b990f1805556486a60ef5dc4029e14e3.0 Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKc1a4.5e1fc4ee20c0782184fc0cd77e60e289.0 Max-Forwards: 67 From: "01752691155" <sip:01752691155@sipconnect.sipgate.de>;tag=as2555b591 To: <sip:0049366511397811@sipconnect.sipgate.de>;tag=23031DE8-43D Call-ID: 7fd1eae14a1f94a35df8beb31a57a33e@sipconnect.sipgate.de CSeq: 103 ACK Content-Length: 0 Feb 1 07:59:14.033: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:22134146t7@192.168.77.201> Date: Sat, 01 Feb 2020 07:59:14 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 Server: Cisco-CUCM12.0 CSeq: 101 CANCEL Content-Length: 0 Feb 1 07:59:14.033: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 487 Request Cancelled Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:22134146t7@192.168.77.201>;tag=111403~badef395-9309-48d9-8bf8-030362ac44b2-55015452 Date: Sat, 01 Feb 2020 07:59:14 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 CSeq: 101 INVITE Allow-Events: presence Server: Cisco-CUCM12.0 Content-Length: 0 Feb 1 07:59:14.033: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: CANCEL sip:+491736749872@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254> Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 User-Agent: Cisco-CUCM12.0 CSeq: 101 CANCEL Max-Forwards: 70 Privacy: none Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=2ef0fca8f9245695ac8b187badc32b63 Content-Length: 0 Feb 1 07:59:14.037: //36133/8E5EF03F89B2/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:7811@192.168.77.201:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220914BA From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=23031D84-240B To: <sip:22134146t7@192.168.77.201>;tag=111403~badef395-9309-48d9-8bf8-030362ac44b2-55015452 Date: Sat, 01 Feb 2020 07:59:07 GMT Call-ID: 8E5F8C67-43FF11EA-89B8E80A-8109750A@192.168.83.254 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=00000000000000000000000000000000 Content-Length: 0 Feb 1 07:59:14.037: //36134/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254> Date: Sat, 01 Feb 2020 07:59:14 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 CSeq: 101 CANCEL Session-ID: 2ef0fca8f9245695ac8b187badc32b63;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 07:59:14.041: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: CANCEL sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220BC34 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150> Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 102 CANCEL Max-Forwards: 70 Timestamp: 1580543954 Reason: Q.850;cause=16 Content-Length: 0 Feb 1 07:59:14.041: //36134/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 487 Request Cancelled Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254>;tag=23033090-213D Date: Sat, 01 Feb 2020 07:59:14 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 CSeq: 101 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.7.3.M5 Reason: Q.850;cause=16 Session-ID: 2ef0fca8f9245695ac8b187badc32b63;remote=5ef89e0f7af051a486054e00b7492dfd Content-Length: 0 Feb 1 07:59:14.045: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:+491736749872@192.168.83.254:5060 SIP/2.0 Via: SIP/2.0/TCP 192.168.83.200:5060;branch=z9hG4bK1dae149cff53b From: "01752691155" <sip:01752691155@192.168.83.200>;tag=551504~badef395-9309-48d9-8bf8-030362ac44b2-55015453 To: <sip:+491736749872@192.168.83.254>;tag=23033090-213D Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: b89b4a00-e3512fcd-1b8cc-c853a8c0@192.168.83.200 User-Agent: Cisco-CUCM12.0 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: presence Privacy: none Content-Length: 0 Feb 1 07:59:14.073: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 canceling Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY PUBLIC IP;branch=z9hG4bK220BC34 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=38f019e33a135542ca386fc4eada6cee-0c69 Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 102 CANCEL Content-Length: 0 Feb 1 07:59:14.073: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 487 Request Terminated Via: SIP/2.0/UDP 192.168.83.254:5060;rport=64217;received=MY PUBLIC IP;branch=z9hG4bK220BC34 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=as6a0d7701 Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 CSeq: 102 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH Supported: replaces Content-Length: 0 Feb 1 07:59:14.077: //36135/B89B4A000000/SIP/Msg/ccsipDisplayMsg: Sent: u allACK sip:+491736749872@217.10.68.150:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.83.254:5060;branch=z9hG4bK220BC34 From: "01752691155" <sip:22134146t7@217.10.68.150>;tag=230325CC-1921 To: <sip:22134146t7@217.10.68.150>;tag=as6a0d7701 Date: Sat, 01 Feb 2020 07:59:09 GMT Call-ID: 8FA3ACF8-43FF11EA-89BEE80A-8109750A@192.168.83.254 Max-Forwards: 70 CSeq: 102 ACK Allow-Events: telephone-event Session-ID: 5ef89e0f7af051a486054e00b7492dfd;remote=2ef0fca8f9245695ac8b187badc32b63 Content-Length: 0
02-02-2020 04:10 AM
OK, so let's look at the Invite you're sending to the service provider for the diverted call leg. Specifically the Diversion and P-Preferred-Identity. We need to check firstly that your putting out the numbers that you intend, and secondly that the formatting an choice of optional headers matches the service providers requirements.
Diversion first. You're presenting the number 2XXXX146t7 as the diverted number. Is that correct? I would not expect to see Xs in a phone number, and not sure the relevance of "t7" at the end either. However this number complete with the t7 is what you have configured in your profile and I see some other settings forcing "t7" onto numbers. I would have thought you'd want to show the original dialled number 49366511397811 to show it is a valid number being diverted. However it depends on the service provider.
Secondly P-Preferred-Identity. Has the SP specifically asked for this, it's not a default header so I guess somewhere you have explicitly enabled it. I note the incoming invite from the SP doesn't use it. Again to be confirmed with the SP, on a diverted call should this show the original calling number or the diverted number.
Maybe an idea to forward just this invite to the SP and ask them what's wrong with it. Then we can work out how to accommodate their requirements.
02-03-2020 11:47 PM
I have sent this INVITE to my Service Provider.
I will post the answer here and than i hope we can solve this problem.
Thank you for your help again.
02-04-2020 01:09 AM - edited 02-04-2020 01:45 AM
So i have a very fast provider.
They answered me this:
You are sending the number in the P-Preferred-Identity header in the wrong format 01752691155:
P Preferred Identity: "01752691155" sip: 01752691155@192.168.83.254
The correct format would be 491752691155.
They also told me that they only need the correct P-Preferred-Identity header and than it has to work.
Am i correct if i say we dont need the diversion header?
How can i achive this and where i have to configure this? (CUCM or Cube)
We tested it with this change:
voice class sip-profiles 1 request REGISTER sip-header From modify "(<.*:)(.*@)" "<sip:226XXX6t7@" request ANY sip-header From modify "(<.*:)(.*@)" "<sip:226XXX6t7@" request INVITE sip-header To modify "(<.*:)(.*@)" "<sip:226XXX6t7@" request INVITE sip-header P-Preferred-Identity modify "(<.*:)(.*@)" "<sip:49366511234@"
This works! But we always see the same number 49366511234 on our mobile phones - so how can i get this working in dynamic mode?
02-04-2020 01:52 AM
You need to modify your sip profile to have the valid DDI of all your extensions.
So if your extensions are 0175269XXXX
Then configure your PPI as follows
request INVITE sip-header P-Preferred-Identity modify "<sip:0175269(.*)@(.*)>" "<sip:49175269\1@\2>"
