ā08-02-2011 04:26 AM - edited ā03-16-2019 06:15 AM
Good day
I've installed and succesfully registered new ip phone 9971. but the expansive module CKEM stil isl not active. How to enable it? Thank you
ā08-02-2011 12:04 PM
Make sure under the phone configuration page you have selected the CKEM under the "Expansion Module Information" section. Also make sure the 9971 has downloaded the correct firmware that is on your call manager and not the out of the box firmware.
ā08-03-2011 09:27 AM
Version of firmware is sip9971-9-2-1 now. I've selected CKEM in the Expansion Module Information" section. But the module is still unavailable. If i try to insert module into the phone the following message appears on the screen "The phone is unable to power this accesssory". Power supply is implemented with PoE+ switch, and now only a few ports are active in it. Do you know what does this message mean? Thank you
ā03-19-2013 07:20 AM
Is there a solution to this? I'm currently experiencing the same issue on a 9951 phone with load 9-3-2-10
Ruben
ā03-19-2013 07:33 AM
For CKEM to work when 9971 is working on POE, we need to have local power adaptor connected to CKEM.Is it connected?
regds,
aman
ā03-20-2013 03:43 AM
It depends on the type of PoE switch which is used. We are using 3560 802.3AF switch so we do need a power cube to power the CKEM.
Power Requirements
Ruben
