CKEM with CME 9.1
Aaziz AMHAOUCH
Hi all,
We have 8961 and 9951 ip phones configured with CME 9.0, now we have to add CKEM modules to this phones. The problem is the CME 9.0 doesn't support this modules.
Some discussion says that CKEM will be supported with CME 9.1 included in IOS 15.2(3)T !! is this true ? and how can I configure this module on CME?
Thank you very much,
Best regards
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Cross-Platform Release Notes for Cisco IOS Release 15.2M&T
http://www.cisco.com/en/US/docs/ios/15_2m_and_t/release/notes/152-2TNEWF.html
The first link show the current Compatibility Matrix.  The second link shows the new features released in the last 3 versions of 15.2 and does not indicate any new changes to CME in the latest 15.2(3)T release.  If not specifically called out, the features for CME 9.0 are used from previous release 15.2(2)T.
Hope this helps.
5 Replies 5
paolo bevilacqua
From Cisco documentation IOS 15.2(3)T still have CME 9.0, so as of today, there is no solution.
So for CKEM support one has to wait for a later release at an unknown date.
Thank you Paolo for your response, but I can't find this in Cisco documentation (which specify that IOS 15.2(3)T still have CME 9.0), can you send me the link of this documentation ?
Best regards
Hope this helps.
Thank you for your help,
Best regards
n-kirillov
Now compatibility matrix says it's supports KEM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme91spc.html
       But configuration still stay at dark place...
Good luck
CCIE, Irkutsk, Russia
Sincerely from Nik
