Clear Placed, Missed and received calls - CUCM
Jose Arango
Hi team
I want to know if I can configure under the service parameter for Placed, missed or received calls through IP Phone services,  a timer for  clear the logs?
Jose Luis Arango
Aaron Harrison
Hi Jose
Please see my post here : https://supportforums.cisco.com/message/1083377#1083377
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Hi Jose
Aaron
Jaime Valencia
No you cannot, there is a method using the idle url and a small .xml file to do such thing. Search CSC and you should be able to find it quite easily
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
