CLI command
j.huizinga
Level 6
Level 6
Is there a command to see how the callmanager was booted? from power failure or from a clean shutdown?
thanks,
JH
6 Replies 6
Jaime Valencia
No, there is no CLI command to get any of that info
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
OK,
Should be implemented though!!!
This is critical!
Bye,
Jan
Get in touch with your AM if you want to submit a PER for that
java
java
Thanks, I will
Jan
Although there's no CLI command for that, as Java said, I think it could be workaround by researching performance counters, alerts, traces and audit logs from the RTMT to determine the cause of a callmanager restarted.
Maybe Java can confirm whether this is feasible.
Hope it helps,
- Adrián.
Good thinking, I shall also have a look at this.
Jan
