Click to Call in Office 2003
kmccoy
I'm running into problems getting Click to Call to work in Office 2003 applications. Click to Call seems to be functioning properly in Internet Explorer but not Word and Excel. Right-clicking on a number doesn't generate the "Call" or "Call with edit" option from either of these applications. I thought it might be a disabled DLL or the add-in not functioning. I've looked at those and still am not seeing the call options in Excel. Here are the versions worth mentioning:
XP SP3
Office 2003 SP3
CallManager 8.5(1)
IP Communicator 4.0
Click to Call 7.0
Any suggestions or leads would be apprecaited. Thanks!
ken
dijohn
Whats the version of C2C?
dijohn
Can you try C2C 8.x?
You can Try CloudConnect Click to Call solutions. CloudConnect is the best click to call service provider in India, they supply high-quality Click to Call Solutions and APIs to small and medium-sized businesses in India. With their pan-India coverage, two you can permit your internet site site visitors to call you right away and FREE
https://www.cloud-connect.in
